soundcraft spirit m4 mixer troubleshooting
  • petehall347
    • Jan 2015
    • 4434
    Re: soundcraft spirit m4 mixer troubleshooting
    what does it connect to ? eg r398
    • 5inc
      • 120
      • Spain
      sorry, bottom right corner, had a 170% zoom
      • petehall347
        • Jan 2015
        • 4434
        i can see it on the pic of board but no use to me ..tell me what it connects to .?
        i am wanting to know whats its job is . i cant find it on the schematics .
        • 5inc
          • 120
          • Spain
          ok! i think you nailed it! it appears it goes to the sleeve of all outputs!!
          • 5inc
            • 120
            • Spain
            sorry, it took me so long because I haven't got it completely out of the case, i had to look against a light to be able to trace at the back of the board from a side
            • petehall347
              • Jan 2015
              • 4434
              #26
              what outputs ?
              • 5inc
                • 120
                • Spain
                #27
                P/B, MIX, Monitor,both left and right and mono sum.
                • petehall347
                  • Jan 2015
                  • 4434
                  #28
                  still cant find it on schematics ..
                  thing is sleeve on jack sockets is generally ground .
                  • petehall347
                    • Jan 2015
                    • 4434
                    #29
                    bingo ..found it ..its page up bottom left .. looks like resistor loading between AGND2 and AGND ...
                    i would connect it if lk3 lk6 arent connected
                    • petehall347
                      • Jan 2015
                      • 4434
                      #30
                      am thinking someone was trying to tame ground hum .. so long as something is connected between the grounds it should at least produce sound
                      • petehall347
                        • Jan 2015
                        • 4434
                        #31
                        skimming through the manual it appears these grounds are floating and not connected to the chassis .
                        • 5inc
                          • 120
                          • Spain
                          #32
                          It's way past my bedtime, I'm not seeing right and starting to mess things up. I'm going to bed, tomorrow evening, with time, I'll make a few pics, try to upload them, and explain you what I have here.
                          Because as I was taking the board appart to solder that link i had a closer look at the board from behind and I saw that it didn't go to gnd, but to a resistor that isn't there, and a few other odd things.
                          see you tomorrow
                          • petehall347
                            • Jan 2015
                            • 4434
                            #33
                            i must sleep too ..yes some pics will help here ..the schematics are presuming the unit is in the same place as i am ...
                            • 5inc
                              • 120
                              • Spain
                              #34
                              Okay lads, I woke up early to do the homework before i get to work, here are the links to the pictures.
                              back side overlook
                              Link part(wire added thinking it had tipped off, and re-disconnected when I saw the next parts)
                              resistors missing beside cn6
                              wires to ground from r547
                              back side closeup, resistors wired to ground(extended to the screw beside JK9)
                              I also realized the two resistors on the last pic, were split in between them, where they join the green wire. I'll replace those and see, before I re join LK58.
                              With this done, I will be back at noon
                              • 5inc
                                • 120
                                • Spain
                                #35
                                ok, re-connected the resistors, and now the 4 return peak leds light up :S
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5016
                                  • New Zealand
                                  #36
                                  I think what needs to be done is a check on the schematic and find where these wires have been connected and try to find why.
                                  They could be to replace blown tracks, part of a legitimate conversion/mod, or some bad attempt to workaround a problem they couldn't fix.
                                  The fault you're seeing now may be related to the original fault if these wires are indeed some repair attempt.
                                  -David VanHorn
                                  • 5inc
                                    • 120
                                    • Spain
                                    #37
                                    I'm back, and it appears now the peak lights aren't staying on :S I've tried a couple outputs and it aint fine though.
                                    Ok agent, I'll do that after dinner, my turn to cook today, I'll make a little diagram of what links where and also I'll write down all the wee resistors and caps missing, and we'll see from there.
                                    • 5inc
                                      • 120
                                      • Spain
                                      #38
                                      ok, on one side I'm missing:
                                      LK58
                                      Resistors: 37,62,223,224,334,335,364,378,397,455,475 and 666
                                      Capacitors: 228,258,261,273 and 317.
                                      And on the other I have this extra:
                                      A link from R547/C313/TR15 to pins 5/6 of CN8.
                                      An other from C315 to gnd, (the screw beside CN8)
                                      Then CN9 pin 2, is sent along a wire through the back of the board to the next board, to a point where it should join R79/R80 to gnd, but the line that goes to gnd is cut off.
                                      On the same CN9 pins 5,6 also go through the back of the board, to c11/c18, the line going to gnd is cut off aswell.
                                      These 3 pins are gnd so they are all shorted together.
                                      4 links at what appears to be return gains,
                                      R258 to R177,
                                      R257 to R183,
                                      R264 to 189,
                                      R265 to R195.
                                      And the last is a wire that goes from the second screw at the top of the top board, trhough a 75ohm resistor to ring in L monitor out and another 75ohm resitor to ring in R monitor output.
                                      That's all I could work out for now. I don't know Who did this and why, I'll try and find out. But it seemed to work fine untill it got wet at a party. Or so I've been told.
                                      • petehall347
                                        • Jan 2015
                                        • 4434
                                        #39
                                        i dont have the brain power right now to start working out why someone did all that to it . best guess is grounding problems .
                                        i think its best to narrow it down into sections starting from power supply then input boards .
                                        you need a signal tracer or scope really ..
                                        • 5inc
                                          • 120
                                          • Spain
                                          #40
                                          yes it's late...
                                          I have the signal tracer still unused, tomorrow i'l check out what it does.
                                          • Longon
                                            Behringer Pro Mixer DJX-750
                                            by Longon
                                            Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                            08-11-2025, 02:17 PM
                                          • BigOof
                                            Marantz SR5007 popping on volume change and mute in Direct Mode
                                            by BigOof
                                            I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                            12-12-2024, 06:15 AM
                                          • Bektronics
                                            Schematic Digital Audio mixer RCF type M18
                                            by Bektronics
                                            Hello dear audio friends.
                                            I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                            The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                            I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                            Thanks in advance if anyone can help me with this schematic.
                                            Of course, all information about this digital mixer and possibly references...
                                            07-24-2023, 06:40 AM
                                          • blues_spirit
                                            practical courses for troubleshooting pc motherboards
                                            by blues_spirit
                                            Hello from France,
                                            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                            Do you think this is feasible for me? I...
                                            12-18-2022, 12:56 PM
                                          • Thermaltake
                                            Yahama mixer PSU difference
                                            by Thermaltake
                                            I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
                                            I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
                                            And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
                                            I google a little and found that there is this part number...
                                            09-17-2024, 11:52 AM
