Pioneer HU RCA issue (tried some fixes)
  • TheDragon
    • Feb 2011
    • 69
    • UK - 230 v
    Hi all, as per title, I have the common pioneer car stereo RCA buzzing issue.
    I recently acquired a fully functioning HU from ebay, model :KEH-P8400R.
    Its rather an older unit that plays cassettes but has CD control and/or AUX input. Perfect for my carPC, plus I wanted the retro look and my favorite old Pioneer logo and font.
    Anyway, it was functioning. I had it temporarily connected up, drove with it, partially inserted and sounded great, with all the glorious tape hiss.
    Then the next day, I came to fully fitting it. Everything was wired up properly and then the dreaded RCA buzzing (alternator whine) was heard.
    I tested with a friends spare HU, the RCA cables to the amp are fine. I checked my amp ground connections, worked fine. No noise with tester HU.
    I then set about grounding the pioneers RCA shields (a typical fix for possible blown pico fuse). This shielding repair did not work.
    As my system is older, I cannot find an pico fuses and there are no mention in the service manual.
    I really want his unit working, it was a hard find on ebay. Can anybody shed any light what could be the issue. Are there some hidden fuses or other component that could be blown and defunct-ed the RCA connections ?
    The service manual can be found here:
    https://www.manualslib.com/manual/95...eh-P8400r.html
    I really do hope someone can help.
    Appreciate it
  • madan1
    • Nov 2016
    • 722
    Re: Pioneer HU RCA issue (tried some fixes)
    After all you have tried, this might sound stupid, but try connecting the head unit's chases to the amp's chases with a wire.
    • TheDragon
      • Feb 2011
      • 69
      • UK - 230 v
      Hmm interesting idea. The amp is in the back, but there is a wire in the middle of the RCA cables, I could use that. I'll try this tomorrow and report back. thx
      • TheDragon
        • Feb 2011
        • 69
        • UK - 230 v
        Sorry about delay in replying. Got busy in holiday season and family things.
        I did as you suggested. It may have helped somewhat, though I can still hear the alternator whine at low volumes, but once volume is lifted and car is moving, not much can be heard. Its more prevalent with car idling than when in motion.
        I guess my only choices are for complete reduction. Get stereo repaired or use RCA isolation devices ?
        thx for suggestion
          When you were testing it the first time and you did not hear the alternator whine, were both units metal bodies bolted to the car chassis? You can try RCA isolator as you suggested.
          Or something like this?
          https://www.amazon.com/PAC-CSS12-Pas.../dp/B000CEDZBA
          BTW, how are the audio RCA cables routed? Close to the noise source?
          • TheDragon
            • Feb 2011
            • 69
            • UK - 230 v
            Thanks for the assist.
            No, the units were not bolted per se, but both units have good solid grounds connected (Which I did check were still good as a maintenance procedure before connecting the HU and amp).
            In all honesty, the HU was just replacing the old dead one. The harness was wired in and soldered with heat shrink. All the return speaker/RCA cables were in the same route functioning fine under previous unit.
            Thanks for that optional part link.
            I did also find this on youtube:
            https://www.youtube.com/watch?v=jbv9PUC0xPk
            From which would indicate I need the ferrite core filter.
            I have a few salvaged ferrite coils laying around, so simple enough to make and test.
            That part you suggested perhaps does the same thing?
            On a side note. I see that you have a few topics in your signature.
            The inverter one caught my eye. Was wondering what you knew about inverters in relation to electroluminescent displays?
            This Pioneer unit has such a display. There is a distinct buzz coming the display and the wired interverter block.
            Some say it's part of the units characteristic, but one would doubt that Pioneer would pass such engineering with such obvious buzzing sound.
            I had thought about replacing the electroluminescent sheet behind the LCD, as the brightness seems dim.
            The inverter itself looks clean and tidy. No bad or loose solder joints.
            Not even sure if it also needs replacing too. Do these 'wear' out?
            Thanks once again
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
              🛠 Original Issue
              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • GraphicMan
              Pioneer A-205 faint noise/hiss issue
              by GraphicMan
              as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
              what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
              out of curiosity what does that mean?
              thanks
              05-19-2024, 11:45 AM
            • ugamazing
              Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
              by ugamazing
              I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
              We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
              12-17-2024, 07:05 PM
            • shahnld
              Lenovo legion 5 pro startup issue
              by shahnld
              Good day Experts
              I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
              A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
              And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
              08-24-2025, 12:31 PM
            • ahmarzo
              Acer laptop battery draining issue
              by ahmarzo
              Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
              Help me to diagnose this issue as there is no shortage in the inputs MOSFET
              08-02-2025, 06:39 AM
