Help identifying the chip.
  • maxslo
    • Nov 2013
    • 64
    • Slovenia
    My Enermax Aeroodio stopped playing sound thru one speaker, from what i was able to conclude, this chip doesn't provide any output to the left speaker circuitry, (right one is working as supposed to).
    Does anyone have an idea what this chip might be? Enermax only describes it as "DreamBass Soundchip", and searching it by the markings yielded no success :/
    Thanks in advance Badcaps Gurus
    Re: Help identifying the chip.
    Can we the pictures of the whole board?
    So you have verified that the power amplifier circuit for the non-functioning speaker is OK?
    • maxslo
      • Nov 2013
      • 64
      • Slovenia
      I'll take it apart again tomorrow and take a photo of the complete board from both sides
      Yeah i did. everything up to that chip seems to work as supposed to.
      • Chungalin
        • Jul 2014
        • 422
        • Spain
        IC is a TQFP-48 package, but I can’t identify maker.
        • maxslo
          • Nov 2013
          • 64
          • Slovenia
          Ok, so here are the photos of the board
          • Khron
            • Sep 2006
            • 1350
            • Finland
            And how exactly did you conclude that main microcontroller is at fault?
            Those two SOIC-8 packaged chips seem to be the power amps, according to the (chinese-only) datasheet. If anything, i'd kinda rather be suspecting those, assuming shoddy contacts aren't the issue.
            That, or crapped-out pots...
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • madan1
              • Nov 2016
              • 682
              I've seen dozens of that single-chip-audio-solution in mp3 players, fm transmitters, cheap amps, etc.
              Usually they are the last thing to fail. If you trace back the signal paths you will easily find the output pins of the chip.
              First check:
              speaker connections
              speakers
              volume pot(s)
              and after that the preamps and the processor.
              • maxslo
                • Nov 2013
                • 64
                • Slovenia
                I've already ruled out the speaker and speaker connection.
                the first thing i did was swap around the speakers,
                both worked fine in the right side,
                but neither worked when pluged in the left side connector.
                After that i grabbed a multimeter and checked voltages for right and left side,
                nothing seems to reach the amp on the left side iirc, i'll check again to be sure.
                volume pot? as in potentiometer? haven't thought about checking that, i'll do that, thanks
                • maxslo
                  • Nov 2013
                  • 64
                  • Slovenia
                  Geez, looks like i did a bad job last time,
                  it seems that it actually is the amp that isn't working,
                  any simple way of testing it and is there any drop in replacement that is perhaps available in eu,
                  the only TC6805 that i've found are from aliexpress
                  • madan1
                    • Nov 2016
                    • 682
                    Check the power - if TC6805 is actually Ltc6805 ( http://pdf1.alldatasheet.net/datashe...R/LTC6800.html ) there should be +/-5V on pins 4 and 8.
                    Then you can check if there is input audio signal from the processor ( by oscilloscope or headphones ).
                    And if the voltages and the signal are OK, then replace the amp.
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      Even simpler, you can compare pin voltage readings with the chip on the "good" side
                      • maxslo
                        • Nov 2013
                        • 64
                        • Slovenia
                        Originally posted by madan1
                        Check the power - if TC6805 is actually Ltc6805 ( ) there should be +/-5V on pins 4 and 8.
                        Nope, not the same, completely different pinout than on the TC6805.
                        Yea, the working one gives me voltage between pins 5 and 8,
                        the faulty one doesnt give anything.
                        Other pins are the same on both chips.
                        Edit: i've found chips with same pinout, except for the input, all of the available chips have a + and - inputs, this TC6805 chip only has one input. :/
                        https://cdn.badcaps-static.com/pdfs/...8b14e1e912.pdf
                        https://cdn.badcaps-static.com/pdfs/...a0676c58ba.pdf
                        Any chance i can make it work with something like this?
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          Completely different pinout, and completely different device
                          In the datasheet i linked earlier, in-between all the chinese characters, i see mentions of EMI and PWM, which would lead me to believe there's a good chance the TC6805 is in fact a compact BTL class-D amplifier. That's pretty much confirmed seeing the fSW = 350kHz in the parameter table on page 2.
                          • maxslo
                            • Nov 2013
                            • 64
                            • Slovenia
                            My bad, those were SOIC-8 i need SOP-8,
                            So something like this could work?
                            https://cdn.badcaps-static.com/pdfs/...9a689b8df6.pdf
                            Edit: ah ok, so it's best if i just buy a couple of these from china and keep as a spare in case they decide to die again sometime :P
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                              Common SPI bios chip programming Questions and Answers
                              by SMDFlea
                              Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                              A: If you can`t read from it how do you expect to write to it ?.
                              Q: Why is my bios chip unreadable ?.
                              A: The programmer is faulty or has a worn or broken zif socket.
                              The USB cable is frayed,connector pins worn or some other physical damage.
                              Not enough amperage or voltage to power the programmer properly.
                              Bad...
                              09-02-2021, 04:40 PM
                            • trepachka
                              Help identifying this chip for Yoga 7 16IRL8
                              by trepachka
                              This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
                              A photo of the chip is attached.
                              Thank you....
                              06-22-2025, 11:13 PM
                            • tyler123456
                              Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                              by tyler123456
                              Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                              I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                              I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                              Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                              Anyone...
                              08-16-2024, 12:51 PM
                            • BMCappelletti
                              Asus Chromebox CN62 - wrong chip put on BIOS reader
                              by BMCappelletti
                              Long story short:
                              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                              - gave the computer to his son a couple years later
                              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                              (seems like the story was not that short)
                              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                              01-08-2025, 07:27 PM
