Philips DS9800W/10 red blinking of death. Revive via JTAG?
  • hasefroch
    • Apr 2013
    • 42
    • Argentina
    A friend have this set of wireless speakers. When powered up, makes the power up sequence led blinks and never gets to connect to a wifi previously set nor generates an own wifi after a reset as it should. Just keeps the red led blinking.
    From the little info that I found on the web, this means that the firmware is corrupted, and the only solution is send it to Philips to repair.
    Still, got the service manual that I attached. It mentions a 'upgrade' port that appears to be a JTAG port.
    The connector PCB pinout read: 3.3V, TCK, TMS, TDI, TDO, GND
    This connector goes to the LM3S800, where the PCB have test points that read: TDO, TDI, TCK, TMS
    My guess is that via JTAG I have a shot to revive this guy, but I don't know what adapter and software use to do that. Until now, never needed to revive anything via JTAG.
    Ideally I want to read first the actual firmware, and (if possible) compare it with the update available before flashing the new. Maybe an additional obstacle is that the download available is mentioned as "update only", so can be a incomplete flash file (in a router, usually this means that the bootloader is not included in the update)
    Suggestions? Thanks in advance.
  • Tarzan
    • Oct 2020
    • Netherlands
    Re: Philips DS9800W/10 red blinking of death. Revive via JTAG?
    Thank you for the service manual. Did you ever find a solution?
    • Panui
      • Aug 2025
      • germany
      I have the same issue! did you find a solution?
      • SluggerB
        Tivo Series 3: Green blinking light of death
        by SluggerB
        Anyone familiar with these old Tivos and the blinking green light issue they can develop?
        Someone sent me one that is exhibiting the issue, and I've been taking reading around the board and comparing them to a known good Series 3 Tivo motherboard I have, and so far the only different I can find is a difference in diode reading on a voltage regulator. However when I swap over the voltage regulator from the good Tivo to bad Tivo, it shows the diode readings of the original component, so something else is causing the issue
        Power supply is good so I know it's not that....
        07-14-2023, 09:12 PM
      • Raulnn
        Philips 43pft4112/12 blinking standby
        by Raulnn
        good evening. I have this basic tv, with an all-in-one board. This tv has a common fault in the primary power area. the tv did not turn on. I bought a repair kit. I have installed all the parts of the kit, but now the tv turns on the standby light intermittently but does not start. the flashing is very fast. What can be? Does anyone know the model? Thank you
        01-08-2023, 04:13 PM
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • Protker
        Philips 47PFH4109 blinking 2 times when powering
        by Protker
        Hello!
        So i have a Philips 47PFH4109, and when i powering on the tv just blinks once, then after a 2 seconds blinks again, and does not turning on.
        I mean i measuring voltages such like 30V on the leds and the 12 volts on the other panels, which seems to be okay.
        I checked the backlight no issues with the leds.
        I checked every component such as all the mosfets, all the diodes, i dont see any bad capacitors (unfortunatelly i only can measure up to 200uF).
        I even took out the LD7591 chip and without it doing the same as before.
        Im just seeking for advice,...
        12-23-2021, 12:33 PM
