Marantz ST-4000
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Marantz ST-4000
    Hello all and sorry for my english. I would like a little help with my Marantz ST-4000 tuner. The tuner waw working normally and suddenly went off. When it is pluged the standby led is on as always but if i try to turn the tuner up the monitor doesn't show anything. I have not sound on speakers too. I opened and tested four transistors on power supply, all diodes and zeners and are all ok. I tested and resistors too and nothing goes wrong. I dont replaced electrolytic capacitors because they seemed good but i dont measured them for ESR and capacitance. In the power supply out connector i have 6 pins and i have those voltages:
    POWER: 3,75V
    GND: -
    remote control: -
    FL2: -25,9v
    Vfip: -32V
    FL1: -25,8V
    Are those voltages ok or is there pissible to have bad power supply? Any idea what to ckeck? Thanks in advance!
    Re: Marantz ST-4000
    Those Voltages you show are for the Fluorescent display.
    How about the the Regulated 12V Voltages? You have two of them per service manual 3. BLOCK DIAGRAM.
    See page 5 and 6 for the actual circuits.
    • vagos_89
      • Apr 2014
      • 61
      • Greece
      Re: Marantz ST-4000
      thank you for you reply! yes i tested these 12V voltages and was ok. I found the problem. I decide to test the power push button after all measurements, and YES i had faulty power push button. Than you for you interest again!
      • Mark R
        Marantz Model 150 Tuner "NULL" Adjustment..
        by Mark R
        I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
        Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
        12-30-2024, 03:18 PM
      • Capacitorial
        Powersupply has all the voltages - Monitor still no power
        by Capacitorial
        Hello guys,
        I have a Philips 240B7QPJEB. The monitor seems completely dead.
        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
        The weird thing is, that the Power LED is powered over the TCON board.
        On The TCON...
        12-28-2024, 02:12 PM
      • DXseekerMO
        Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
        by DXseekerMO
        I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
        As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
        09-15-2021, 05:15 PM
      • benspawn02
        Anthem MRX500 - no sound. R2A15218FP issue??
        by benspawn02
        Dear Electronics Experts:
        I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
        08-12-2023, 04:46 AM
      • Mark R
        Marantz Model 120 Tuner Craziness I am Stumped!
        by Mark R
        My Marantz 120 Tuner stopped receiving Stereo signals. It works fine other then Stereo. I have a fully loaded shop here with all test equipment except and RF signal Generator.
        I get great reception on FM so I have used that signal troubleshoot. I have been all over the MPX board and replaced all caps. Also the entire power supply caps were replaced.
        All Voltages on the MPX board are good... all Transistors Good...All Diodes Good and other components.
        The stereo lamp is good as I powered it up and it lights. The signal flow to that lamp is unbelievably...
        10-20-2023, 01:25 PM
