Part needed for Onkyo amp
  • tech2014
    • Aug 2014
    • 807
    I have an amp that when powered up, comes up with "Check SP wire" then shuts down. I found a shorted output transistor on the heat sink. Its has TTA0001 printed on it. This part is obsolete according to mouser and digikey. Does anyone know of a replacement part or where I can find these parts.
    thanks
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Part needed for Onkyo amp
    First of all, you'll want to replace its TTC0001 "partner" on that channel, as well, "just in case".
    Second, some OnSemi transistors should be a close-enough match, i think. In the same case size, the MJW3281A / MJW1302A should fit the bill.
    https://cdn.badcaps-static.com/pdfs/...ef5a9f32a2.pdf
    They should be easily available from the "usual suspects" (Farnell/element14, Digikey, <insert-your-favourite-supplier-here> etc).
    That being said though, it may be well worth checking things further upstream as well (driver transistors), to try to make sure you don't directly blow the replacements.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • redwire
      • Dec 2010
      • 3906
      The Toshiba TTA0001 power transistor is still in production, but their semi's are awful to find. Digikey and Mouser have 500pc min. buys for the part.
      2SA1943N is the closest sub I could find.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Not to mention the amount of Toshiba fakes floating around...
        http://sound.westhost.com/counterfeit.htm
        • ngvuanh
          • Jul 2013
          • 36
          tech2014, you don't need to find exact.
          You only need to find similar Vcb, Vce, Veb and Pc.
          2SA1962 and 2SC5242 work just fine for you.
          • tibimakai
            • Jan 2012
            • 3680
            Check some of my posts with Onkyos. I mention there, what kind of transistors I'm using.
            Definitely check all the parts, on the pre-amp board(vertical board) and everything on the main board, around the final transistors and vertical board.
            I guaranty, that you will find, at least 4-8 bad components.
            It would help, if you would mention in the title, which Onkyo do you have.
            • G-Sting
              iPad Pro A1876 SHORT Part Identify Help Needed
              by G-Sting
              So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
              So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
              i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
              SO My main concern is what part should i order what should i search the name for ?
              on Ipad...
              05-15-2025, 09:30 AM
            • edugimeno
              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
              by edugimeno
              Hi There!
              I'm trying to help my friend who owns a restaurant be just bought.
              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
              It's stuck using, I guess, the 2 sided tape that comes with the strip
              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
              09-05-2024, 09:34 AM
            • quickname
              Cyberpower 1500AVR UPS repair
              by quickname
              I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
              I decided to verify that the batteries were...
              11-12-2023, 09:57 AM
            • vbogoev
              Lenovo S6000 won't turn on. Data recovery needed.
              by vbogoev
              Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
              Code:
              [PWRAP] pwrap_init_preloader
              [PWRAP] pwrap_init
              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
              [PMIC_WRAP]wrap_init pass,the return
              06-20-2023, 06:36 AM
            • Goblin999
              RTX 3060 EVGA - Part Discover Help Needed
              by Goblin999
              Hello , I have this 3060 EVGA card that doesn`t work . Measured for shorts and resistance , seems ok . Powered it up but doesn`t work , GPU chip is cold . Though this part circled in red is getting very hot and pretty fast so I suspect this is the reason . Can somebody help me discover what this part is . Maybe a data sheet or a similar part ? Thanks...
              02-10-2022, 09:09 AM
