Harmon Kardon HK490i no output left channel
  • Wehan
    • Jul 2015
    • 30
    I was given a Harmon HK490i receiver years ago and it worked awesome. I was forced to store it for a few years and when I got it back out the left channel was really fussy cutting in and out but if I fiddled with the balance knob I could get it to work fine. I used some air in a can to blow out the balance knob but it did not help. Had to store it again and now the left channel is gone. If I have the volume knob all the way down the right speaker is silent while the left you can hear the input source very faintly (like someone has their headphones up loud across the room) but if I even slightly turn the volume up the left goes out and its all gone. I have the service manual I will attach hopefully someone can help me out.
  • Longbow
    • Jun 2011
    • 623
    Re: Harmon Kardon HK490i no output left channel
    Blowing air at the controls won't do anything. You need to use some DeOxit cleaner on your front panel switches and controls.
    Is it plugged in?
    • Wehan
      • Jul 2015
      • 30
      Ok, I'll give that deoxit a try, any specific one I should use?
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        Deoxit D5.
        sigpicThe Sky Is Falling
        • Wehan
          • Jul 2015
          • 30
          Thanks, on order now!
          • Wehan
            • Jul 2015
            • 30
            SUCCESS!!!! Thank you so much Longbow and rhomanski, the deoxit worked wonderfully...took a few treatments and a bunch of working the knob back and forth but it works great now. I went ahead and gave every knob and switch a shot of it and they are all dead silent now! Now all it needs is a dead lamp replacement and she will be shinning like a diamond.
            • Sik_6ty_Sixx
              HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
              by Sik_6ty_Sixx
              So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
              02-18-2025, 05:06 AM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
            • HelpMeRepair
              Yamaha RX-A3010 left channel no signal
              by HelpMeRepair
              Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
              what I did so far ,
              factory reset
              test all other channel
              tone test
              dissasemble and look , visual inspection witout full dissasembly
              looked at all the mosfet for temperature to see if they eas operating
              scratch my head couple of time
              thanks in advance all help is appreciated , service manual are welcome too ! =)...
              11-14-2024, 02:48 PM
            • sima112
              Marantz pm 6005 right channel not worknig
              by sima112
              Hi guys,
              I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
              01-30-2023, 12:11 PM
            • eccerr0r
              old X58 triple channel board... memtest86 memory speed?
              by eccerr0r
              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
              06-28-2025, 09:06 AM
