Technics SA-5550, powers on but no sound.
  • johnboy1313
    • Nov 2012
    • 1959
    I found this in a dumpster. I've fixed many TVs at this point but no audio equipment yet. It powers on. It plays a weak sound through at least one side of the headphones but it's not loud at all. I was using my iphone earbuds with a 1/4" mono adapter so I don't know for sure if one side doesn't work through the phones jack or if the adapter was causing it. I opened it up and noticed the burnt spot in the pictures. I don't know the insides of audio equipment like I know TVs so I really don't know where to go from here. Something failed violently. It looks like only one of the transistors (TR603) near the burned mark is shorted and a couple resistors are toast. Both of the speaker circuit protection fuses are missing. I probed the clips that hold the fuses for voltage and continuity to ground. When power is on, the left channel fuse show about 190mv. The right channel shows 14.45V. The other clip on the right channel is shorted to ground. Ive attached the service manual and a few pics. I can provide more when needed.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Technics SA-5550, powers on but no sound.
    I'm on my phone now so I can only post one pic at a time.
    • johnboy1313
      • Nov 2012
      • 1959
      • johnboy1313
        • Nov 2012
        • 1959
        Another pic
        • johnboy1313
          • Nov 2012
          • 1959
          Schematic for the burnt board.
          • johnboy1313
            • Nov 2012
            • 1959
            TR604, TR606, TR607, and TR608 are all shorted as well.
            • eccerr0r
              old X58 triple channel board... memtest86 memory speed?
              by eccerr0r
              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
              06-28-2025, 09:06 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • spleenharvester
              Reverse engineering of 18650 4-channel tester
              by spleenharvester
              Hi friends
              I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
              05-04-2025, 02:43 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
