Help differentiating/identifying capacitor types
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Help differentiating/identifying capacitor types
    105 will give you longer life. Important for me because I am not going to need to replace them again. It's like my cousin told me, a roofer asked him if he wanted 20 year shingles or 25. He said at the time he thought about it," let's see, I'm 78 now, so..." He said "Give me the 20 year." He'll be 83 this year and the shingles are doing fine.
    Another thought is what if they come up with some totally different capacitor in the next 10 years and discontinue these old style ones. They may not be physically compatible. These kids today are going to look back on smd's with fondness and tell their grandchildren, "Yeah, we used to cook our circuit boards in the oven, don't need to do that anymore though".
    sigpicThe Sky Is Falling
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Well, the thing is, you won't find 85C low-ESR caps On the other hand, there's a reasonably good chance that 105C general-purpose caps might be rated for higher ripple-currents than an 85C same value/voltage one, but you'd have to check datasheets for that
      And why might mixing (GOOD) brands be a bad thing?
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • thespeakerport
        • Mar 2016
        • 17
        I have no hard evidence to back this up, but I would expect that every manufacture does something a little different than the other for a given series of caps. The way they behave in given application should be consistent (IMHO) and I really don't know if this 'behavior' can be guaranteed by mixing different makes/models. Maybe, may be not. Maybe the differences are so negligible that it is a waste of time to even talk about.
          • 30917
          mixing wont matter for smoothing power, but if it's for dc blocking in audio each make/series will have a different filtering effect - some will have more bass or treble than others.
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • Ambro
            Help identifying missing smd capacitor for HP elitebook 840 g3
            by Ambro
            In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
            I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
            I've attached a picture of where it's located on the board.
            Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
            Thank you for any help you can provide....
            09-09-2023, 06:21 PM
          • grimacelord
            Need Help Identifying Capacitor On Kar-Tech Versa Remote
            by grimacelord
            I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
            One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
            09-08-2023, 09:28 AM
          • krob80
            PS5 Edm-010 No Power - Help identifying missing capacitor
            by krob80
            Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
            It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
            When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
            I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
            05-15-2025, 04:24 PM
          • chunk69
            Looking for help in identifying Kuang Jin capacitor from PSU
            by chunk69
            Hi friends,
            I recently acquired an old PC power supply (along with several vintage motherboards from late 90s/early 2000s). The PSU was dead upon first test, but quickly identified the internal fuse had blown. I fixed that, re-tested and i'm pleased to report it seemed to work great after that - no obvious issues or reasons for the fuse to blow.
            Afterwards, I inspected the capacitors more closely and noticed one pair required replacement. They weren't in bad shape by any stretch of imagination, but one was slightly bulged, and I wanted to swap them out for good measure....
            12-06-2023, 04:35 PM
