onkyo ht-r580
  • harleyman58
    • Feb 2016
    • 89
    • usa
    onkyo ht-r580
    has anyone had any experience with this receiver? I have video through the hdmi and when it is turned on. but no audio you can here a light buzzing that does not get any louder when you increase the volume. any thoughts will be appreciated.
    thank you kenny
  • Agent24
    I see dead caps
    • Oct 2007
    • 4955
    • New Zealand
    Re: onkyo ht-r580
    Do you get audio with other inputs or is it just the HDMI which doesn't work?
    Have you tried another cable? Is the signal source known good?
    -David VanHorn
    • harleyman58
      • Feb 2016
      • 89
      • usa
      Re: onkyo ht-r580
      none of the hdmi put out audio, also the radio will not work, or the headphones.
      • harleyman58
        • Feb 2016
        • 89
        • usa
        Re: onkyo ht-r580
        service manual
        • Agent24
          I see dead caps
          • Oct 2007
          • 4955
          • New Zealand
          Re: onkyo ht-r580
          If you get nothing from any input, check for a general fault in the amplifier section.
          Do you know how to do signal tracing?
          -David VanHorn
          • harleyman58
            • Feb 2016
            • 89
            • usa
            Re: onkyo ht-r580
            no I don't know where to start,im just learning the audio side of electronics, I did electronic repair on industrial equipment.
            • Khron
              • Sep 2006
              • 1350
              • Finland
              Re: onkyo ht-r580
              Hint #1: page 4
              Hint #2: page 15
              Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
              • harleyman58
                • Feb 2016
                • 89
                • usa
                Re: onkyo ht-r580
                ok on page 18 I have a green, yellow, and black wire from the main transformer. I see what I think is the protection circuit relays from a 110 volt feed. I think the main feed goes throught the relays and power the rectifier then the filter caps which is to be 52.5 volts but I get 85 volts on the 1 and 4 pins of the rectifier. the 52.5 volts go to the amp section. what am I missing?
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4955
                  • New Zealand
                  Re: onkyo ht-r580
                  It's a split-rail power supply with a +52.5 (+B1H_B) and -52.5 rail (-B1H_B)
                  So you should actually be measuring about 105v across pins 1 and 4 of the bridge rectifier.
                  Measure each rail separately and see if they're both low or if just one is low. You can use the rectifier's heatsink as ground ref.
                  Also might pay to check your meter on a known good voltage source as the meter could be bad or the battery flat.
                  Now would also be a good time to post a bunch of photos of the inside of your amplifier.
                  -David VanHorn
                  • harleyman58
                    • Feb 2016
                    • 89
                    • usa
                    Re: onkyo ht-r580
                    ok pin 2 to ground 42.7v ac, pin 3 to ground 42.7v ac, pin 1 to ground 57.5v dc, pin 4 to ground 57.5v, pin 2 and 3 85.2v ac, pin 1 and 4 114v dc, when I power the receiver up I get a click just as soon as I push the on button, 3 seconds later another click, 3 seconds after that the last click and the speakers start humming. pictures coming next
                    • harleyman58
                      • Feb 2016
                      • 89
                      • usa
                      Re: onkyo ht-r580
                      pictures inside of 580
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        Re: onkyo ht-r580
                        If the relays do click, and SOME signal does end up in the speakers, then it should be reasonably safe to assume that whatever issue is present, is before the power amps.
                        If there was some power amp problem (DC on the output, or some short in the output transistors), some protection would've triggered, and the output relays wouldn't have clicked on.
                        See my post #7.
                        • harleyman58
                          • Feb 2016
                          • 89
                          • usa
                          Re: onkyo ht-r580
                          I found some caps I think are bad c 9023, c9025,c9026,c9028,c9030. going to pull them to make sure. these caps are on page 20.
                          • harleyman58
                            • Feb 2016
                            • 89
                            • usa
                            Re: onkyo ht-r580
                            caps were not bad! this thing is making me mad. going to have to take some blood pressure meds.
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              Re: onkyo ht-r580
                              Ok, i'll try to spell it out: in my post #7, the pages i indicated contain what seem to be block diagrams / signal-flow diagrams for the various audio paths, from the inputs all the way to the power amps & outputs.
                              I'm sorry, but noone here on the forum can do the testing for you, no matter how much we'd want to
                              • harleyman58
                                • Feb 2016
                                • 89
                                • usa
                                Re: onkyo ht-r580
                                ok on page 17 on the + and - 15 volt supply, q4171 was grounded. d4304 is bad letting voltage flow both ways. cut d4304 and q4171 went back to ungrounded. if everyone thinks this was the problem, I am going to replace q4170,q4171,d4304,d4305,c4170,c4171,c4172,c4173.
                                input please thank you kenny
                                • Khron
                                  • Sep 2006
                                  • 1350
                                  • Finland
                                  Re: onkyo ht-r580
                                  "Q4171 was grounded" = you mean its output was shorted to ground?
                                  If D4304 was shorted, then that would make sense. For now, replacing only that diode should be enough at least for a test.
                                  Although since that -15v rail (along with the -7 derived from it) supply basically all the opamps, as well as that multiplexing / source switching chip, its absence would indeed explain the lack of audio.
                                  • harleyman58
                                    • Feb 2016
                                    • 89
                                    • usa
                                    Re: onkyo ht-r580
                                    yes the output was shorted to ground
                                    • harleyman58
                                      • Feb 2016
                                      • 89
                                      • usa
                                      Re: onkyo ht-r580
                                      I would like to report that the bad diode was the problem with the audio. running the receiver for a few days just to make sure. I would like to thank the badcaps forum, and AGENT 24 and KHRON for all their help.
                                      thank you kenny
                                      • Khron
                                        • Sep 2006
                                        • 1350
                                        • Finland
                                        Re: onkyo ht-r580
                                        Glad we could help
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • ai.need.help
                                          Onkyo TX-8050 AV-Receiver no sound
                                          by ai.need.help
                                          I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
                                          It doesn't play music. There is no real output from:
                                          pre-out
                                          amp-out A and B
                                          phones out
                                          The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
                                          I tested with analog-input, usb and radio.
                                          I know that there is a common problem with...
                                          12-20-2022, 05:54 PM
                                        • wolf1976
                                          wireless receiver for 6 speeds fan control with remote control
                                          by wolf1976
                                          hi i have a receiver that is destroyed from the overvoltage i guess
                                          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                          the motor fan has not label
                                          i have an other receiver operational
                                          In your opinion can i measure the voltage at the output ?
                                          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                          thanks in advance...
                                          07-23-2025, 03:12 PM
                                        • budwich
                                          onkyo 919 Receiver... hum problem but...
                                          by budwich
                                          I have an onyko 919. It has a hum problem at cold start which eventually dies / goes quiet. I have been "chasing" it for a while. Tightening ground screws and checking a few places. Basically, the problem is in the "back half" of the unit.... that is, if I take the sound out of the "pre-out" and feed it to a stand alone amp, it is good. If I feed in a signal at the external decoder input and play thru the back end of the onkyo, it has the hum.
                                          Anyway, along the way (the chase), a number of components (resistors, capacitors, etc) on the main board...
                                          01-13-2021, 03:31 PM
                                        • CdDvdFlash
                                          DSE GE6878 possible TV receiver dying remote not working well
                                          by CdDvdFlash
                                          For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                          07-03-2024, 03:55 AM
