I have an Onkyo TX-DS797 av amp that I am trying to repair. We had a 600v power surge thanks to local power company that took out the units standby power supply. Unit was not on so I think the main transformer and guts is ok but the standby power supply is always on to feed the microprocessor and work the relay to enable the main power supply.
Upon debugging I found the primary coil of the standby power supply blown.
Im having a challenge to find a suitable replacement transformer as the original model seems to be an unlabeled proprietary unit made by tamura:
Original Transformer:
onkyo npt-1111d (2300670A)
From looking at tamura website I was able to find a standby transformer design factor with same dimensions that shows it is ~2.5VA model
Since it is blown I cannot measure the output voltage. From the service manual it seems the output of the power supply is labeled as 13v. The schematic for the standby supply shows it is a simple full wave power supply.
Basically the transformer feeds diode bridge 4xRL1N4003 and a 220uf cap and 4.7k resistor in parallel with the output.
If I do a basic calculation for the required transformer VAC:
Vtran = (13 + 0.7*2)/1.414 = 10.1838
Where I am a little challenged is in understanding how to account for the regulation factor of the transformer.
If I purchase a 10vac transformer with a 25% regulation factor as I find on digikey:
http://www.digikey.com/scripts/DkSea...16101542782866
Im guessing that the minimally loaded standby mode may be as high as 12.5v instead of the 10v resulting in a supply voltage of 16.6v instead of the target 14v which is substantially higher.
From google it seems that a more realistic minimally loaded transformer will have 15% higher voltage and the 25% is too pessimistic I might consider using a 9v transformer. This would give a 13.23v result, but would potentially drop lower if the standby power uses closer to the 2.5watts.
Dont have another similar amp that I can plug in to see how much power it draws at standby. I would appreciate any tips/pointers in helping decide on a suitable replacement.
