Mackie 1400i
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Mackie 1400i
    Hi guys got this one from a coworker to fix, downloaded a great service manual (major props to Mackie for actually wanting these to be fixed)
    after testing I have a big list of replacement parts but had a question about the resistors on the base of the main transistors, about half of them are open. The SM specs them as 2.2 ohm .25 watt fusible and I am having a difficult time sourcing a replacement. Is it safe to use a regular metal film resistor in this instance?
    Also one of the main filter caps has a reddish substance on the top that looks like it is leaking but seems to pass other tests, they are on back order until march. I'm not positive if its bad or not anyone seen similar leakage from these? I'm wondering as it doesn't look like the electrolyte I normally see leaking?
    Parts list so far
    r7, r13, r15, r29, r33, r34, r36
    q28, q42, q15
    d19, d20, d88, d89
    c12
    f4, f5
    Liberating magic smoke one part at a time
    Re: Mackie 1400i
    You can use MOX Flame proof resistor for the 2.2 Ohms.
    • Caleb
      Smokin IC's
      • Feb 2013
      • 645
      Re: Mackie 1400i
      Still coming up empty, closest thing I can find is 1/3 watt. Im not sure how close the tolerances have to be on these? I do have a gob of mox resistors, but not sure if they are flameproof, I guess I could try to burn one up and see if it flames or not.
        Re: Mackie 1400i
        Metal Oxide resistors are Flame proof.
        1/3 Watt will be fine, that is an odd Wattage rating.
        • Mark D
          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
          by Mark D
          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
          10-29-2024, 03:15 PM
        • Deby
          List of compatible laptop motherboards
          by Deby
          This is a list of compatible laptop motherboard information that I have been collecting for some time.
          And it's still ongoing.
          Every time I come across information that a board is compatible with another, I write it down.
          Anyone who wants to, can continue to expand the list.
          Packed in the rar, is an excel table that has additional information.
          Motherboards.rar...
          05-31-2024, 04:34 AM
        • madan1
          Mackie Th15 SMPS low Vout
          by madan1
          I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
          It is basically a smps with amp and some dsp.
          The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
          Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
          By the way, the ferrite core of L10 is broken,...
          02-16-2025, 04:15 PM
        • MarkRocket
          list of PS5 Internal Fuses
          by MarkRocket
          This is not a definitive list, and I do not claim if it is 100% accurate so please do your own research, based on the information from littlefuse, RS, Farnell and a few other places, using information about the markings on the fuses
          Please feel free to distribute, amend, correct, etc...
          01-31-2025, 07:11 AM
          Samsung UN82NU8000FXZA LCD TV Parts List
          Samsung UN82NU8000FXZA 82" LCD TV Parts List...
          11-01-2024, 06:16 AM
