Kenwood KR-A4070 Sound issue
  • tech2014
    • Aug 2014
    • 807
    The sound is very low. You can crank the volume up fully and not a lot of sound. I am not very familiar with audio circuits. Can someone look at the schematic and tell me where to look. I do have a 70MHz oscilloscope. Any help would be greatly appreciated?
    Re: Kenwood KR-A4070 Sound issue
    Did try cleaning the controls and switches first?
    This unit uses lots of electronic switch ICs (IC 102, 104) for routing the audio signals which do go bad.
    Since you are getting low sound form both channels I would then look at the circuits that are common to both channel by checking to make sure the power supply Voltages are OK, also make sure all the boards mounting screws are tight and not corroded which will cause bad Ground connection to the chassis.
    You can also look at the audio signals on CN101 RIN, ROUT, LIN, LOUT.
    The schematic is kind of bad due to multiple pages you need to link them together.
    • tech2014
      • Aug 2014
      • 807
      thanks budm. I did find that one of the connectors says -30V, but when I measured it I only got -25v. I agree the schematics suck.
        I think the -30V is used for the FL (Fluorescent Display), I need to look at the SCH.
        • tech2014
          • Aug 2014
          • 807
          I input audio to the CD input port and I do get Left and Right audio going into IC104 and out of IC102.
          I get nothing at CN101. What does IC106 do? Its says UP/DOWN.
            Volume Control motor drive.
            • tech2014
              • Aug 2014
              • 807
              thanks. I am suspecting IC104 since I get nothing at CN101.
                If you look at PDF page 18, CN101 PIN 3 is the LEFT channel power amp input, pin 6 is the Right channel power amp input.
                Q101, Q102 are the MUTE transistors for the power amp inputs which should be turned off in normal operation (not in MUTE mode).
                So what audio signal do you see at the CN101?
                • tech2014
                  • Aug 2014
                  • 807
                  I can't see anything at all.
                    So you do see audio on pin 21 INPUT (L) of IC104 but no output on pin 19 (L)?
                    BTW, the diagram shows IC104 PIN19, 20, 21 are tied together directly!, SAME FOR 8, 9, and 10 for the Right channel. Is that how they are connected?
                    • tech2014
                      • Aug 2014
                      • 807
                      I did see -1.6V on the base of Q101 and Q102. Are they supposed to be 0 when in mute or is this normal. Im done for the day. I will get back to it tomorrow and get back to you on my findings. Thanks for the help, learning lots today.
                      • tech2014
                        • Aug 2014
                        • 807
                        Found something strange. I think the input selector IC may be shot. When testing the other inputs, like the CD/TAPE/PHONO, I had the audio connected to the TAPE 1/REC input, and I was getting normal sound. Problem is I can change the input to TUNER or CD, and still get sound. Should only be sound coming out of the input selected. Since there was no audio connected to the CD or PHONO inputs, but I get normal sounding audio coming out, would this point to the input selector. I even get sound out of the TUNER even though there is no antenna connected.
                        I also noticed that if I get low sound on the CD input when there is audio signal, if I toggle between inputs, and select CD, I can get the sound back to normal again.
                        • tech2014
                          • Aug 2014
                          • 807
                          I'm confused. I input the sine wave and trace it to CN101. I get L and R IN but no L and R OUT. I get normal volume out of the speakers
                            'Problem is I can change the input to TUNER or CD, and still get sound. Should only be sound coming out of the input selected. ' That is correct, I wonder if it is stuck in one of the input mode, you may have to try feeding each input to see which one will give the normal sound level.
                            You also verify that the TAPE MONITOR is not activated, right?
                            • tech2014
                              • Aug 2014
                              • 807
                              I have CD input selected using the sine wave as a signal. For some reason, no matter what input I select, I have a signal on pin 3 and pin 26 of both IC102 and IC104.
                              I connected the signal to TAPE 2 MONITOR, I get signal out of REC but not PLAY. Same on TAPE 1
                              • tech2014
                                • Aug 2014
                                • 807
                                So could it be IC102 and IC104?
                                • tech2014
                                  • Aug 2014
                                  • 807
                                  Pin 3 and 26 of IC102 are always on no matter what input is selected.
                                  • tech2014
                                    • Aug 2014
                                    • 807
                                    I found bad solder on IC, resoldered and works now.
                                    • ex250
                                      Kenwood SW-505D no sound issue and pops from time to time when it works
                                      by ex250
                                      Hello mates,
                                      I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                      It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                      12-29-2024, 03:27 PM
                                    • benspawn02
                                      Anthem MRX500 - no sound. R2A15218FP issue??
                                      by benspawn02
                                      Dear Electronics Experts:
                                      I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                                      08-12-2023, 04:46 AM
                                    • ctebke
                                      DELL 3501 MB la-k034p Sound issue
                                      by ctebke
                                      Hello, I have dell 3501 MB la-k034p with Sound issue RED cross. No sound device in device manager. In BIOS diagnostic everything passes but no sound tone either in bios test. AUDIO chip is CS42l42 and 3.3v, 1.8v is present. Someone have any idea ? Thanks.
                                      11-21-2025, 08:09 AM
                                    • JRade
                                      Audio video receiver KENWood KR-V990D,no sound
                                      by JRade
                                      When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                      The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                      I replaced the capacitor C303/0.047F, nothing changes.
                                      I'm asking for help, what should I do next?
                                      Thanks in advance!...
                                      08-05-2025, 10:23 PM
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
