The sound is very low. You can crank the volume up fully and not a lot of sound. I am not very familiar with audio circuits. Can someone look at the schematic and tell me where to look. I do have a 70MHz oscilloscope. Any help would be greatly appreciated?
Kenwood KR-A4070 Sound issue
Re: Kenwood KR-A4070 Sound issue
Did try cleaning the controls and switches first?
This unit uses lots of electronic switch ICs (IC 102, 104) for routing the audio signals which do go bad.
Since you are getting low sound form both channels I would then look at the circuits that are common to both channel by checking to make sure the power supply Voltages are OK, also make sure all the boards mounting screws are tight and not corroded which will cause bad Ground connection to the chassis.
You can also look at the audio signals on CN101 RIN, ROUT, LIN, LOUT.
The schematic is kind of bad due to multiple pages you need to link them together.Last edited by budm; 12-02-2015, 08:09 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
I think the -30V is used for the FL (Fluorescent Display), I need to look at the SCH.Never stop learning
If you look at PDF page 18, CN101 PIN 3 is the LEFT channel power amp input, pin 6 is the Right channel power amp input.
Q101, Q102 are the MUTE transistors for the power amp inputs which should be turned off in normal operation (not in MUTE mode).
So what audio signal do you see at the CN101?Last edited by budm; 12-03-2015, 05:55 PM.Never stop learning
So you do see audio on pin 21 INPUT (L) of IC104 but no output on pin 19 (L)?
BTW, the diagram shows IC104 PIN19, 20, 21 are tied together directly!, SAME FOR 8, 9, and 10 for the Right channel. Is that how they are connected?Last edited by budm; 12-03-2015, 06:09 PM.Never stop learning
I did see -1.6V on the base of Q101 and Q102. Are they supposed to be 0 when in mute or is this normal. Im done for the day. I will get back to it tomorrow and get back to you on my findings. Thanks for the help, learning lots today.Last edited by tech2014; 12-03-2015, 06:10 PM.Comment
Found something strange. I think the input selector IC may be shot. When testing the other inputs, like the CD/TAPE/PHONO, I had the audio connected to the TAPE 1/REC input, and I was getting normal sound. Problem is I can change the input to TUNER or CD, and still get sound. Should only be sound coming out of the input selected. Since there was no audio connected to the CD or PHONO inputs, but I get normal sounding audio coming out, would this point to the input selector. I even get sound out of the TUNER even though there is no antenna connected.
I also noticed that if I get low sound on the CD input when there is audio signal, if I toggle between inputs, and select CD, I can get the sound back to normal again.Last edited by tech2014; 12-04-2015, 02:29 PM.Comment
'Problem is I can change the input to TUNER or CD, and still get sound. Should only be sound coming out of the input selected. ' That is correct, I wonder if it is stuck in one of the input mode, you may have to try feeding each input to see which one will give the normal sound level.
You also verify that the TAPE MONITOR is not activated, right?Never stop learning
I have CD input selected using the sine wave as a signal. For some reason, no matter what input I select, I have a signal on pin 3 and pin 26 of both IC102 and IC104.
I connected the signal to TAPE 2 MONITOR, I get signal out of REC but not PLAY. Same on TAPE 1Comment
by ex250Hello mates,
I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...-
by benspawn02Anthem MRX500 - no sound
Dear Electronics Experts:
I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...-
by JRadeWhen I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
I replaced the capacitor C303/0.047F, nothing changes.
I'm asking for help, what should I do next?
Thanks in advance!...-
08-05-2025, 10:23 PM -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by saisoni20Hi,
I have A2337 MacBook Air no sound issue.
I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
In terms of voltages, I have following voltages,
1 PP1V25_AWAKE_IO - 1.2V
2 PP1V25_AWAKE_IO - 1.8V
3 SPKRAMP_A_OUTP_R - 0V
4 SPKRAMP_A_OUTN_R - 0V
Am I missing any other critical voltages?
Thanks - Loading...
