Pioneer SA-510 finicky stereo sound, lots of popping noise and a possible bad cap?
  • Deses
    • Oct 2015
    • 8
    • Spain
    Hi everyone!
    I'm taking a look at one vintage piece of equipment from my dad, a nice Pioneer SA-510 straight from 1980. It has been inside a box for the last 10 years or so and today I tested if it turned on and it sure did! But the stereo sound is a bit wonky, I have to wiggle the audio jack to achieve stereo sound, the audio pops when turning the volume and it very distorted.
    I then opened the chassis and I didn't see anything really wrong apart from a capacitor with a black stripe o the top. I'm not sure if that's just black marker or fluid leak. Here are some pictures. It looks marker to me, but other pictures of the board I found on the Internet doesn't show that so I'm really not sure. But then again those are really old Japanese caps from before the capacitor plague, sooo probably marker, yeah.
    Here's the board diagram if anyone is interested in that. The cap I'm talking about is in Page 5, square 3-A, C54.
    About the knobs making noise when turning, I guess my best bet would be resoldering the potentiometers or replacing them?
    I really don't know where to begin with this or how could I identify the problems, so any help is appreciated!
    • 31218
    Re: Pioneer SA-510 finicky stereo sound, lots of popping noise and a possible bad cap
    you need to clean or replace the pots, switches etc.
    i cant tell you the caps are fine, but a black line is marker.
    • Compgeke
      • Feb 2014
      • 524
      Pots and switches for sure. Pick up some Faderlube and that'll work wonders on the pots. If you can't find that, I've found Deoxit D5 works alright usually, however stronger ones will eat the carbon traces.
      I've fixed at least 10 amps\receivers that have the same problem you described and is almost always just a good cleaning. The few exceptions are 60s gear that should be recapped even if it worked right.
      • montemcguire
        • Mar 2015
        • 15
        Pots and switches often get 'crunchy' when there's DC passing through them, which happens when the electrolytic coupling caps are ancient and leaky, and fail to block DC from the switches and pots. Before you put a huge pile of possibly damaging gunk into the pots and switches, replace all of the electrolytic coupling caps. They're from the Ford administration - they're not expected to work anymore. Modern caps work better anyway.
        The good part is that, while the switches and pots are impossible to replace, the electrolytic caps are actually easy to replace. Please do that, since you cannot replace the switches and pots, and they are probably not bad anyway.
        Best of luck!
          • 31218
          you would be surprised about a lot of switches & pots - most are still production designs.
          • GraphicMan
            Pioneer A-205 faint noise/hiss issue
            by GraphicMan
            as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
            what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
            out of curiosity what does that mean?
            thanks
            05-19-2024, 11:45 AM
          • tony359
            by tony359
            11-28-2023, 05:18 AM
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • courtcircuit
            Philips HTS8000 home cinema noise problem
            by courtcircuit
            Hello
            I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
            Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
            Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
            I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
            Removed each of tyhe boards
            02-08-2025, 08:22 AM
          • Bushcat
            Pioneer PL-X9 motor speed control wobble
            by Bushcat
            I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
            Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
            BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
            05-24-2023, 03:36 AM
