TEAC v8060 receiver. Volume control not working at all
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    I picked up this receiver for cheap at an estate sale (about $20). I was under the impression it was in working order, but after plugging it in, I notice that all the buttons seem to respond except the volume The LED on the dial lights up, and the remote will also turn the volume, but there is no indication of volume control on the display , and output appears silent. The only other problem I'm noticing so far, is that the video3 button looks like it was forced in at some time , and is also not functioning.
    I know that I've sort of fixed a similar problem on a small JVC unit. It was a pain, and basically had to take apart the volume pot and clean up , etc. Would it be a good idea to try to fix this?
    master hoarder
    • May 2008
    • 12175
    Re: TEAC v8060 receiver. Volume control not working at all
    Seems like a decent amp, so why not? Take it apart and post some pictures. Maybe it's only bad solder joints.
    • fzabkar
      • Mar 2009
      • 772
      Service manual:
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        What is the output amplifier Class?
        • fzabkar
          • Mar 2009
          • 772
          Class AB
          • fzabkar
            • Mar 2009
            • 772
            Does the headphone output work?
            If you apply an audio signal to the VIDEO3 input, do you get any output?
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Originally posted by fzabkar
              Class AB
              Then I would repair the stereo.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                [QUOTE=tucocaps;601305]I picked up this receiver for cheap at an estate sale (about $20). I was under the impression it was in working order, but after plugging it in, I notice that all the buttons seem to respond except the volume
                Question? Did you check that both left and right channels have no volume? You most likely did or you should have heard a faint volume with the balance set in the middle position. So if it is both channels that should point you in a direction before L & R channels. Looks like IC24 is common to both or it might just be the master volume control as it also goes to the balance between both channels
                • tucocaps
                  • Apr 2013
                  • 331
                  • United Stated
                  Didn't see my replies to this yet, so had since taken it apart.
                  I may be wrong, but I'm assuming the actual volume control piece would likely be the failure point, as the volume control literally doesn't respond at all (no numbers on display, nothing).
                  I was dismayed to see this volume control is not common. I can post pictures, but basically it appears to be a sealed cylinder with MANY solder joints. The shaft exits one side, and I was able to bend up tabs and remove the front, but it appears the actual control mechanism is not serviceable. Perhaps it's available for replacement, but it may be an expensive part.
                  • fzabkar
                    • Mar 2009
                    • 772
                    The service manual (page 14) depicts VR91 as four ganged potentiometers, a DC motor, and an LED. It should be fairly easy to meter its pins. That said, unless the pots are stuck at the bottom end of their travel, then I wouldn't think that this part would be the culprit.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Question could not corrosion from sitting around in a damp place cause a failure? I don't know how old the receiver is? If it is old and was sitting around in a garage and the potentiometers are the open type and exposed to air perhaps that could cause a failure?
                      • crackedprint
                        Sony HCD-HX80R Amplifier Volume Control Problem
                        by crackedprint
                        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                        I have tried a Cold Reset as per the service manual.
                        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                        I have looked all the way through the service manual and tried many online...
                        01-21-2025, 12:18 PM
                      • wolf1976
                        wireless receiver for 6 speeds fan control with remote control
                        by wolf1976
                        hi i have a receiver that is destroyed from the overvoltage i guess
                        my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                        the motor fan has not label
                        i have an other receiver operational
                        In your opinion can i measure the voltage at the output ?
                        what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                        thanks in advance...
                        07-23-2025, 03:12 PM
                      • CdDvdFlash
                        DSE GE6878 possible TV receiver dying remote not working well
                        by CdDvdFlash
                        For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                        07-03-2024, 03:55 AM
                      • unimatrix93
                        Midea MD1001LF control board not working
                        by unimatrix93
                        I have this high powered microwave over that does not want to start.
                        When I plug it in the mains power, the fan start up but the control panel does not work, no display only the stop button beeps when I press it.
                        I checked main filter capacitors next to the PFC IC (TNY174) they are showing 328V and the IC drain pin is at the same voltage.
                        The transformer has multiple outputs:
                        3v3, -27V, -5V, -12V.
                        Now when the fan is working I measure 17V on 3v3 pin and 5V when the fan stops and relay clicks. I guess...
                        09-04-2024, 06:18 AM
                      • tmhobadcap
                        Pioneer VSX-522-K remote control not working???
                        by tmhobadcap
                        I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                        At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                        12-24-2020, 01:44 AM
