Left channel on amp dropping out after 15mins or so?
  • mikay786
    • Aug 2014
    • 765
    Any suggestions on where I should start, left channel on CD/AMP drops out after about 15mins or so playing.
    Have to turn off and on again to reset.
    Hinari DPA2 CD player with integrated amp
  • mikay786
    • Aug 2014
    • 765
    Re: Left channel on amp dropping out after 15mins or so?
    Could over heating by surroundings cause a problem like described?
    As I can't replicate the issue, left it running for about an hour and hasn't skipped a beat.
    The guy I sold it to had it high up in a little shack / diner place and the unit was very warm when I went to collect it. Heat from cooking related items plus no ventilation. At home at normal temp stood alone it's been cool as a cucumber.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      did you look for the usual bad solder yet?
      Follow the white rabbit.
      • dannyf
        • Oct 2015
        • US
        Could be due to protection kicking in.
        I would open it up and wait for it to drop-out and find the parts that have become hot (too hot to touch with your fingers).
        • Sik_6ty_Sixx
          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
          by Sik_6ty_Sixx
          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
          02-18-2025, 05:06 AM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • HelpMeRepair
          Yamaha RX-A3010 left channel no signal
          by HelpMeRepair
          Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
          what I did so far ,
          factory reset
          test all other channel
          tone test
          dissasemble and look , visual inspection witout full dissasembly
          looked at all the mosfet for temperature to see if they eas operating
          scratch my head couple of time
          thanks in advance all help is appreciated , service manual are welcome too ! =)...
          11-14-2024, 02:48 PM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
