Microphone Oktava 219A stopped working
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Microphone Oktava 219A stopped working
    That's great to hear Congratulations
    Yes, all the solid-state condenser mics nowadays (non-electret) use "normal" 3-legged JFETs
    I've used a small blob of cotton wool (the "bulk" stuff, for medicinal use) and 99.8% isopropyl alcohol (IPA), wrapped quite tight around the (closed) tip of a pair of tweezers. This, plus a bunch of patience, lots of care, and a light(ish) touch worked for me, so far
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      The grounded metal case on the old JFETs was to shield out noise that earlier designs were susceptible to. Modern replacements have been improved to the point they no longer need such localized shielding.
      After cleaning the capsule dry it very thoroughly before powering it up. They are susceptible to moisture damage. If you power one up damp kiss it good-by.
      • skunks
        • Dec 2014
        • 11
        • Ukraine
        Thank you guys!
        Will simple ethyl alcohol 96% work?
        Does it mean I can use 3-leg JFET and dismiss connecting ground? If the only reason of ground connection is shielding, that modern JFETs doesn't require.
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Mylar (the most widely used diaphragm material) shouldn't have any problems with ethyl alcohol either. I found this table from DuPont:
          https://cdn.badcaps-static.com/pdfs/...1144ab4fdb.pdf
          Older condenser microphones (think vintage German / Austrian mics, the likes of Neumann U47's) had diaphragms made out of PVC, which ages far worse than mylar, but shouldn't have issues with ethyl alcohol either (scroll down to page 8) :
          https://cdn.badcaps-static.com/pdfs/...cf8a5fbfd5.pdf
          And yes, 3-legged JFETs are fine
          Just last week, i did some work (mods & upgrades) on a pair of sE 2200A microphones i have. Up-rated the electrolytics, did a bit of re-wiring on the front-end (including replacing the stock 2SK30's with a pair of manually-matched Vishay-Siliconix J305's), and swapped the two ceramic caps for a pair of film caps.
          • redwire
            • Dec 2010
            • 3912
            skunks, I would leave the JFET alone. Toshiba discontinued the part early 2003 I think. It affects the sound quality a lot.
            JFETs have huge variations from part to part, so there are 3 classes for IDSS (2SK170GR or BL or V) and many times they are usually hand-picked to bias for best dynamic range.
            Micross makes equivalents.
