Re: Korg Polysix synthesizer
I think you're just making sure the power supply regulates and doesn't collapse under load. I'd just use car lights #194 (~0.3A) as a dummy load for a quick test.
The +/-15VDC regulators have current-limits about 1.2A, and the 5V regulators 0.6A so I wouldn't load heavier than that.
Note +/-15VDC regulator outputs feed the +/-5V regulators input. So a 0.6A load on the +5V and 0.6A load on the +15V is maxxing it out = 1.2A load on the +15V reg.- they add up.
Output voltages running (service manual) some are tight:
+15.000V +/-0.05V
-15.000V +/-0.3V
+5.000V +/-0.01V
-5.000V +/-0.01V
not at the same time, you will overload it
maybe after the 15v is checked.Leave a comment:
Ok, thanks Budm. Mine measure 21 ohms cold but they're 130v. That will still work and draw around 1/2 amp.
Related and interesting, earlier stj advised me not to use halogen bulbs for current limiting on the ac line because the cold resistance is too low. However I have some 40w 120v halogens that measure 21 ohm cold as well. I think I ought to be able to use them as a load for this as well.
Should I dummy load the 5v outs too?Last edited by SteveNielsen; 09-06-2015, 07:34 AM.Leave a comment:
230v lamps are not that common. I will get it worked out here soon and let you know.Leave a comment:
dont people get "swat"'ed for owning those now!Leave a comment:
You can use 100W 230V LAMP as the load, the cold resistance is around 30 Ohms, you can easily check the cold resistance with the meter.Leave a comment:
So just load one side at a time? I can do that. Better than nothing eh?Last edited by SteveNielsen; 09-05-2015, 03:38 PM.Leave a comment:
Just those two? Might be good enough. Put both in parallel and on the 15v rails should draw about 200mA. Should be good enough to load the transistors and warm them up to see if anything weird happens. Unfortunately you can only test one rail at a time with that though.Leave a comment:
Nope. I've got a 100ohm 10w and a 560ohm 5w, that's as close as I can get without ganging a boatload of 1/2 watts together, and I'm not sure I've got enough of workable values of those.Leave a comment:
Got any 160-200 ohm or so 5 watt resistors? At 17v, Each one will draw about 100mA and dissipate 1.6 Watts. Start with one and add add more in parallel to increase the load.Leave a comment:
No shorts on any of the wires. All the solder joints look ok on the board.
I don't have suitable dummy loads to use. If I shoot for a .5 amp current that will be 7.5 watts and 30 ohms at 15v. Don't have any automotive bulbs.Leave a comment:
I think that must be an unintentional paste at the beginning there Budm
Your explanation makes sense though, thanks.
Redwire, remember this was a no load test. I'll be doing some loaded testing and the other suggestions and keep you all updated.
Thanks to everyone for your interest and help so far. You folks are great.Leave a comment:
"Okay, Pos lead on anode, neg lead on neg leg of C102 reads 117V AC" That may be because the + has more load than the - supply. The +/- power supplies are tracking power supply, so if one goes up or down in Voltage it will track each other.Leave a comment:
Playing with trimmers of any kind is a bad move until you rule out other problems.
R13 or R14 or R17 could have drifted. The thermistor TH1 could be bad. Check values and solder joints on all of them.Leave a comment:
Since the original fuses are 1A, don't go beyond that. Half that at 500mA per rail or so is probably a good start.Leave a comment:
I agree on the dummy load thinking. I just have to see what I've got around here for dummy loads that could work. I think I'll need 3 loads, one for each; -15v, +15v, and +5v. I don't know how much current draw each voltage line should be tested at.Leave a comment:
Well, I do have a heat gunThat'd be overkill though I think.
I don't think I've got any auto bulbs around, but I'll have to look. I've got several power resistors of various values though up to about 5k I think.
The wires are all routed clear of anything that could pinch them but I have not checked them for shorts. I could measure at the test points on the PSU and plug each cable in and check that way, if there's a shorted wire I should be able to narrow it down to a specific bunch that way. Thanks for the good suggestions.Leave a comment:
Would still be smart though to put some dummy load on it and run it for a while.Leave a comment:
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
