Harman/Kardon Onyx Bluetooth Speaker - No Power
  • fzabkar
    replied
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    Would it be worth isolating the reset pin at the PCB (by desoldering it) and then shorting this pin manually? This would also confirm whether the leakage (?) to ground is external or internal. Is this kind of leakage a typical failure mode of MLCCs?
  • Agent24
    replied
    R306 may just be a 0 Ohm resistor, although why they'd use that, I don't know. Maybe they had something higher value there during prototyping and testing, and use 0 Ohm in production.
    Resistors don't fail shorted, and there isn't anything in parallel with it that I can see, so it's probably supposed to be 0 Ohms.
    If Q301 has 0v on the base, it should be turned off. Thus, it should not be pulling reset low.
    BUT... If you are measuring only 781 Ohms across C306 (and incidentally, probably also across C-E of Q301) that could indicate a problem. Try measuring resistance across it again both ways (ie, swap your probes around), see if the readings change. Also might be interesting to see what you get both ways in diode mode too.
    Also can you check if the Emitter of Q301 is connected to ground?
  • caphair
    replied
    Ok I'm getting 0v at base (left pin) of Q301 and 1v on collector (tab) same 1v going into the reset pin.
    Measurements
    R304 - 14.2k ohms
    R306 - 0 ohms - shorted or something in parallel with it shorted?
    R308 - 220k ohms
    C306 - 781 ohms
  • Agent24
    replied
    Originally posted by fzabkar
    Isn't R308 connected between base and emitter?
    BTW, the pinout is BCE.
    Yes R308 is between B-E, I made a mistake the first time.
    Q301 Pin numbers are not correct for SOT23, I think the program defaults to TO92. I've removed them. (Need lunch!)
  • fzabkar
    replied
    BTW, the pinout is BCE (left, tab, right).
    T4 (D301) could be a 2.7V zener or a 1N4148, but it doesn't look like the latter. Perhaps it senses the battery voltage, but I can't see how it would work with Q301 to do this.
  • Agent24
    replied
    That is strange. I would have expected the reset line to be either 3.3v or 0v, never 1v. Perhaps R304 is going high or open, or something is partially shorted (C306 or Q301). Or perhaps I just don't understand the circuit function...
    From what I can see:
    R304 seems to be a pullup, probably to the 3.3v rail. C306 likely provides the debounce and the 5ms delay the datasheet speaks of.
    It looks like Q301 is for pulling the reset line low externally from somewhere else, but what exactly turns it on, I am not sure. I've drawn a schematic of what the circuit seems to be.
    What voltage you get on the base and collector of Q301? Compare these between when reset is 1v and when it is 3.25v and see if there is a difference.
    For pinout, check the datasheet attached. (The Code W1A comes back to PMBT3904 which is a common part)
    Also, can you measure the resistance of R306, R304 and R308?
    Also, do you get any resistance measured across C306?
    Can you post a photo showing the PCB tracks around Q301 with more light? I can't see where the tracks go near C317 and C318 etc.
    EDIT (Mistake in Schematic on R308)
  • caphair
    replied
    Ok this is weird I just measured again and now get 1v on reset pin, however now one side of R304 has 3.25v and the side going into R306 has 1v
    Possible it's bad? Both sides measured 3.25v just a bit ago
    There's also 1v on the lead of that surface mount transistor? That's above R304 the lead that's next to its label Q301
  • Agent24
    replied
    Possibly your probe did not make a good connection the first time. If you get 3.25v on reset, then that sounds normal. In that case, I'm out of ideas unless you have a scope to check the clock.
    The only other thing I could think is giving it a manual reset while the button is pressed by shorting across C306 momentarily. In the event that C306 is open circuit and is not allowing the reset signal to go low for at least 5ms but this is unlikely...
  • caphair
    replied
    Ok that's weird I went to measure again and got no voltages at same pins, measured battery and it was 3.8v so I plugged the charger in and now I have 3.25v on the reset pin as well as on both sides of the resistor you wanted me to check.
  • Agent24
    replied
    Hmm... that does not sound right...
    The BT module can work on 1.8v or 3.3v, and has its own internal 1.8v regulator, which it supplies through Pin 15, and which seems to be working. I assume that 1.8v regulator is powered from either Pin 32 or 34, or both. (Out of interest, what do you measure on those pins?)
    According to the datasheet, the voltage at Pin 13 determines the operating mode. Since you measured 3.3v on the supply pin, Pin 13 - it seems to be operating in 3.3v mode. 3.3v CMOS logic levels require 2v-3.3v for a logic high, so 1v would not be considered a high in that case. In fact, 1v is barely at the threshold for a 1.8v logic high, which is 1.17v.
    Can you take a close up photo of the area above the module where the trace from R306\C306 leads to R304, near Q301? And see what voltage you get on the each side of R304 too?
  • caphair
    replied
    Testing voltage at the reset pin it goes to 1v when power button pressed and doesn't change unless I release power button and then the voltage drops.
    Also measured before the resistor going to that pin and get same voltage (to rule out that the resistor value increased)Does that mean it's staying low?
    Also there is 3.3v present on the VDD pin 13 so it is receiving that voltage as well as 1.8v on pin 15 so that voltage is present as well.
  • caphair
    replied
    Ok that layout confused me with the dimensions? On each pin which are numbered
  • Agent24
    replied
    Yes, you need to measure the voltage at that pin. You will probably need to press the power button too.
    In digital logic terms, low means a zero - or normally 0v, and high means Vcc\supply voltage (In this case, probably 3.3v)
    To be 100% sure the signal is OK, you would need to ensure that during the power-up sequence, the reset line stays low for at least 5ms, then goes high (as stated in the datasheet) This would need to be done with a logic analyzer or digital scope... but that's probably getting ahead of ourselves...
  • caphair
    replied
    How exactly do I check to make sure it's not staying low? Am I looking for a voltage at pin 3?
  • Agent24
    replied
    Go look at the file SPEC-BM153-V4.3_03122009.pdf I linked\uploaded. On page 3\4 it tells you which pins do what.
    Pin 1 on the module is marked with a 1. In your photo, it's the bottom-right corner. From pin 1, the rest are numbered in an anti-clockwise fashion around the edge.
    Pin 3 thus, seems to connect to R306 on the main board. According to the datasheet:
    "Reset if low. Input debounced so must be low for >5ms to cause a reset"
    So you want to check that Pin 3 is not staying low, as that would hold the module in a reset state and nothing would happen.
    You should probably also check power pins, Pin 12, 13, etc to make sure power is actually getting to the module.
  • caphair
    replied
    Thanks guy! How do I go about trying the external reset first? As it seems the easiest
  • fzabkar
    replied
    Curiosity led me to this Onyx Studio FCC database page:
    https://apps.fcc.gov/oetcf/eas/repor...c_id=APIONYXST
    Underneath the heatsink are two TI TPA3116D2 power amps.
    TPA3116D2EVM Evaluation Module
    https://cdn.badcaps-static.com/pdfs/...19c7d8b85a.pdf
    TPA3116D2, 50W Filter-Free Class-D Stereo Amplifier with AM Avoidance:
    The following thread discusses the Harman Kardon ONE device:
    http://www.oluvsgadgets.net/2015/06/...mware-fix.html
    The HK ONE uses the same BM150 module (see the internal photos):
    https://apps.fcc.gov/oetcf/eas/repor...cc_id=APIHKONE
    Just FYI, the following links constitute a firmware update for the HK ONE. I'm guessing that a similar procedure using the same (?) software but different payload would apply to the ONYX STUDIO.
    Uploaded firmware 1.4.1, CSR BlueSuite and installation manual:
    http://putit.ru/download/MjMxNjU3OTYyMTUzOA==
    http://my-files.ru/d58uuf.JBL_CHARGE_2.7z
    http://higgs.rghost.ru/download/89c8...BL_CHARGE_2.7z
  • fzabkar
    replied
    I found one more document that may or may not be of use.
    Here is the FCC page for "a 2.0 Speakers System" manufactured by Guoguang Electric Co.,Ltd (FCC ID: 2AAP8HSBT67):
    https://apps.fcc.gov/oetcf/eas/repor...id=2AAP8HSBT67
    There are two schematics:
    https://apps.fcc.gov/eas/GetApplicat...tml?id=2141465
    https://apps.fcc.gov/eas/GetApplicat...tml?id=2141466
    One of the schematics shows the internal circuit diagram of the Bluetooth module, plus it shows the pinout of the PCB. The module's part number is BM153 rather than the Onyx's BM150, but I believe that they are the same module. According to the Rockbox datasheet, BM153 is the order number for the 3.3V version of the BM150. Also, Sunitec's web site states that the BM150 is "factory configurable to either 1.8V or 3.3V supply". Make sure you order the 3.3V version rather than the 1.8V.
    I don't know if these modules need to be reprogrammed, but I would be prepared for that possibility. In fact ISTM that the Programmable Input/Output Lines would need to be configured by each appliance manufacturer to correspond to their specific button and LED functions.
    BTW, be very careful when buying your module. I found other modules that look very similar but have slightly different pinouts (pins 53-60 are different).
    The following examples are similar but NOT identical to the BM150:
    https://cdn.badcaps-static.com/pdfs/...731f5c4cff.pdf
  • Agent24
    replied
    Looks like it's a BM150 from Sunitec: http://www.sunitec.com.tw/product-it...avi=52&uid=123
    Found a BOM on FCC website: https://cdn.badcaps-static.com/pdfs/...667a2bc897.pdf
    Also found datasheet for the BM150 here: https://cdn.badcaps-static.com/pdfs/...a02ece2fe5.pdf (Page 4 of this document shows the module's pinout)
    Datasheet for Bluetooth chip BC57E687C here: https://cdn.badcaps-static.com/pdfs/...086079d3a0.pdf
    You better hope it's an issue with the external Reset line or something, as I doubt troubleshooting that module would be easy, nor would replacing the chip, unless you can do BGA rework. And it doesn't look like new modules are easy to get either.
    Originally posted by caphair
    I'm wondering, would the company give out the schematic if I contacted them or something they don't make public?
    If you asked nicely and were extremely lucky... you are still unlikely to get it
  • caphair
    replied
    Here's a pic hope it helps. I'm curious to get it going if possible. This thing was $300 brand new. I'm wondering, would the company give out the schematic if I contacted them or something they don't make public?
  • funky2x
    Harman kardon onyx studio 7 Smd code
    by funky2x
    Cant find what smd code Y0DVA.
    sitting in Harman kardon onyx studio 7. Appreciate any help.
    05-29-2025, 03:44 PM
  • dorfman
    Dell Harman Kardon Dead Left Speaker
    by dorfman
    Working on an early 2000s dell / harman kardon computer speakers.
    Suddenly only the right speaker works. No sound is coming out of the left. Also, the right is much louder than when both speakers were working. The minimum volume setting sounds much louder than where I previously set it (half way). And the loudness difference between minimum and maximum position on the knob is small compared to when both were working.
    I checked the signal wire for continuity from the board to the jack. Both channels and the ground are continuous with low resistance and not shorted...
    09-03-2022, 05:39 AM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • magneh
    Harman Kardon Aura Studio 2 speaker - no power - how to identify IC?
    by magneh
    Hi
    Long story short, Harman Kardon Aura Studio 2 speaker, no power.
    Disassembled, found burned IC, maybe the 5V regulator? not sure
    No schematics
    IC marking: 225S2 (see pic)
    Board ref: 40-KS320U-PSK2G
    Thanks for any help!...
    09-16-2021, 08:41 AM
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
