Fuses ??
  • wan901
    • Jun 2007
    • 69
    Fuses ??
    Guys i have Creative Insipire 2.1 speaker....the fuses burn already....the originally fuses is 3.15A 250v.... can i instead changing it to 5A 250V fuses ??
  • Logistics
    • Apr 2007
    • 721
    Re: Fuses ??
    Another 2A is pretty big. If it had a 3A fuse, I wouldn't up it to 5A. Do you have any idea why it blew the fuse to begin with?
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Fuses ??
      Fuses blow for a reason.
      You don't want to give more amps to the reason.
      Mann-Made Global Warming.
      - Dr Seuss
      • starfury1
        • May 2006
        • 1256
        Re: Fuses ??
        fuses have been known to fail of there own accord but not "blown"
        They are a protection device
        Normally replace same with same, 3.15A seem to be a bit hard to find thought so use 3A
        Some are slow blow type and some are fast acting
        I am assuming they either a 3AG or M205 type fuses here but could be other.
        If the fuse was blown apart in side the glass then it points to huge current being drawn this is usually caused by a short of some kind
        I (as above) would first look at WHY it blew.
        Were they (since you say fuses) DC power rail fuses? this could possible mean a shorted power Amp IC.
        possibly shorted speaker wires
        Since you mention creative its seems more likely a power Amp IC would be used then discrete build amplifiers.
        These would most probably have regulators for the power rails so a failed reg could be the cause
        So thats your first step really, find out why they blew
        use 3A if you cant get the same
        As bonez said you dont what to feed the problem more Amps
        Cheers
        You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
          by sam_sam_sam
          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
          12-14-2023, 07:45 PM
        • Sik_6ty_Sixx
          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
          by Sik_6ty_Sixx
          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
          02-18-2025, 05:06 AM
        • MrzPdlch
          Blown fuses on Gigabyte GTX 980TI 6GB
          by MrzPdlch
          Hey everyone,
          I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
          Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
          Find some pictures of the actual GPU together with a picture of how it should look like.
          I also wonder whther it might be a problem that there...
          03-10-2024, 04:14 PM
        • Gadjet
          Looking for a Fuse T4AL/250V
          by Gadjet
          I've got a Monitor that's not showing any video, and I found this blown Fuse. As you can see from the photos, the board location has T4AL / 250V. Any assistance is greatly appreciated. Thanks!...
          06-15-2025, 09:16 AM
