Infinity TSS-1200 Subwoofer issues
  • pllasma
    • Jun 2015
    • 16
    • US
    My Infinity tss-1200 subwoofer started giving me issues a few months ago. It started with a low hum/buzz and occasionally a chirp. Neither were consistent and would happen a few times daily or a few times weekly. Now the subwoofer is not working at all.
    The manual is found Here
    I'm no expert at using meters, when looking at the schematic (bottom of document on the left), I've tested the voltages at AC1/AC3 and they are both around 50V. I've also tested at C4 and C9 (very bottom on right) with their volts ~14.5.
    I also removed one of the large capacitors (3300uF80V) and tested with a capacitance meter. The reading was 2950uF. (Thanks to those who responded in my capacitor post). I also connected a 1.5V battery to charge the capacitor.. The reading was steady at 1.5V dropping 0.01 V every 10-15 seconds. (I have not tested the 2nd capacitor).
    I've also looked over the board and haven't noticed any burnt/bulging caps or resistors, etc.
    I've attached a few pictures. 1 pic is an overall view of the board (it's missing the one capacitor I removed). And there are 2 pics that show a copper coil with some gel-like substance. This gel looks like it's spread out and covered some of the components and went under others. Not sure what the gel is, but is that okay?
    Now I'm at a lose. Can anyone give me ideas on what I should check?
  • lti
    • May 2011
    • 2557
    Re: Infinity TSS-1200 Subwoofer issues
    That looks like glue. It should be okay. It doesn't look like the kind of glue that becomes conductive.
    It looks like C78 is bulging.
    • pllasma
      • Jun 2015
      • 16
      • US
      I took out the cap at C78 and tested it. It's a 330uF16V but reading between 205-250uF. I also pulled another cap that is exactly the same and it doesn't read and capacitance at all.
      So question.. would these bad caps be enough to kill the entire board?
        • 31247
        yes.
        and before you ask, use panasonic FR series and DONT get them from ebay.
        • pllasma
          • Jun 2015
          • 16
          • US
          Originally posted by stj
          yes.
          what about these:
          http://www.frys.com/product/1005523?...H:MAIN_RSLT_PG
          I have a FRY's near me and I would be able to pick them up if they are suitable replacements.
            • 31247
            no, NTE = some surplus crap that has been re-branded.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Definitely glue in the first pic. Oozed electrolyte would be around the leads of the capacitor.
              I'd also suspect any Koshin caps to be failed. They're of very, very low quality. I've even seen a 1uF 50V Koshin cap fail high capacitance and high ESR, and it was only 8 years old.
              Don't buy any caps from Fry's. Source the Panny FR from Digi-Key
              • pllasma
                • Jun 2015
                • 16
                • US
                I've replaced 2 capacitors, but still having issues. Not sure which direction to take..
                  So it is still dead? What DCV do you get between the two legs of those two caps? The power LED is on when the audio input signal is detected?
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Which two caps did you replace?
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • testaccgta
                      Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                      by testaccgta
                      Hi, everyone!
                      I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                      I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                      09-01-2024, 08:24 PM
                    • rustinjust
                      Please help, subwoofer connected to tv, read description below
                      by rustinjust
                      I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                      Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                      Is there a way of...
                      10-28-2023, 07:09 AM
                    • rustinjust
                      Please help, where can I get a remote for my subwoofer?
                      by rustinjust
                      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                      Is there...
                      10-28-2023, 03:43 AM
                    • Takeatry
                      Yet another Samsung QLED Boot Loop
                      by Takeatry
                      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                      10-04-2024, 02:57 PM
