Onkyo TX-NR636, blown right channel. Replaced output transistors and 5W emitter resistors in amp section and some small transistors and resistors on the preamp board. Can't adjust idle properly - turning the pot all the way up doesn't even get me to the minimum suggested starting point in the SM.
Before I move forward... can I isolate the problem using headphones ? ie, if it sounds ok through the phones the preamp is good and the amp section needs looking at ? Have not hooked up speakers and of course don't want to push my luck as the ouputs are still good
. over the years in this field I've serviced repaired many many amplifiers from crown macro tech's, ev p300's to valve amps all brain drainers.. still it's good you nailed it.. sometimes if you have a working channel use it to take ref points volts to nail that nagging fault. current draw can be done via placement of current meter within + or - rails idle would be set cross the emitter resistors and trim things that way and no loading of the amplifier with signal or speaker loads.
