What do I need??
  • stevo1210
    • Oct 2006
    • 4156
    Re: What do I need??
    Originally posted by Spyke
    Yeah, its 12V, same thing as the "On" voltage.
    A lot of models power the low power electronics section with the "Always On" voltage. This almost always includes the display controller as well.
    I know it's been a long time and I have actually bought a proper stereo, but curiosity killed the cat and I decided to connect the 12V cables from my PSU to the "battery" and +12 in terminals and the display came on so I'm pretty happy that the unit works. Now I think this will be one of those "fun" projects for the weekend.
    Thanks.
    • stevo1210
      • Oct 2006
      • 4156
      Soldered in all the required cables today and I'm happy to say that it's all up and running now.
      • nzphil
        Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
        by nzphil
        I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
        04-11-2021, 05:58 PM
      • ngml
        Repair of an LG split AC system indoor unit PCB
        by ngml
        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
        This indicates an error in the communication between the outdoor and the indoor unit.
        The outdoor unit is fine, so the problem is the indoor PCB.
        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
        Does anybody have the schematics of this board,...
        02-01-2025, 12:55 PM
      • nobbnobb1
        Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
        by nobbnobb1
        Hi guys,
        Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
        When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
        02-03-2022, 11:14 AM
      • Gjackson
        Air-conditioning unit power supply failing to power up
        by Gjackson
        Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
        01-08-2022, 09:24 AM
      • Mark R
        Does Changing Out Caps In A Tuner Effect FM Reception
        by Mark R
        "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
        I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
        Any Thoughts?
        06-11-2024, 07:04 PM
