Sanyo M9820K 'boombox' slide switch contact repair?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5085
    • New Zealand
    Got a Sanyo M9820K radio to fix.
    The mode switch was not working properly, wiggling the lever sideways sometimes made the radio come on but not always.
    I found the switch had intermittent\high resistance contact on one group of contacts. I opened it up, expecting severe buildup of crap. No, in fact, one of the contacts has been burnt away almost completely. I guess it's been switching the main power supply and after 20+ years or so it's died. Fair enough.
    It's an ALPS BT566 350F, seems to be 6P3T configuration and which I suspect is highly likely a custom part or at the very least discontinued long ago... (And why the eff do radios always have to have hugely complicated slide switches?? )
    Anyway, does anyone have some clever ideas on how I could fix this?
    I would steal a contact from the band switch, but it uses all 6 sets of contacts too...
    At the moment I'm thinking of just bodging a rotary switch in there somewhere instead, it'll look horrible, but should work...
    -David VanHorn
    • 31277
    Re: Sanyo M9820K 'boombox' slide switch contact repair?
    find some old junk with a load of similar switches and take the contact from one.
    if your only after the spring-contacts then you dont need a 3-bank one.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      You likely won't be able to find one with the same dimensions, but you could get a 6P3T switch and "dead-bug" it on the board. Or, like you said, use a rotary switch.
      Muh-soggy-knee
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
      • SluggerB
        Help making a switch work the opposite way with a relay
        by SluggerB
        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
        02-07-2025, 07:57 PM
      • Powderfanupnorf
        Dell AL440LX power on switch circuit help required
        by Powderfanupnorf
        Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
        So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
        My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
        06-24-2024, 01:24 PM
