Onkyo HT-RC560 transistor question
  • tibimakai
    • Jan 2012
    • 3680
    I have picked one of these up with the same Chk Sp Wire issue, so I have found shorted finals, ceramic resistor, a 2SA1200-Y transistor and another 120Ohm resitor showing a weird number.
    I need to remove these and re check them again, to be sure.
    But I know for sure that the 2SA1200-Y is shorted between C-E.
    I can't find this transistor around here, only in China.
    Which other transistor, could I use in it's place(complementary is 2SC2880-Y).
    I have found something on Digikey, but I'm not good at this and I don't feel confident in choosing a replacement transistor.
    http://www.digikey.com/product-searc...=0&pageSize=25
    I'm working, with the TX-NR626 schematics. I believe, they should be the same.
    In the 636 schematics, there is a INA6006AP1 transistor(Q5441-R channel).
    Any help, would be appreciated.
  • mmartell
    • Oct 2013
    • 3189
    Re: Onkyo HT-RC560 transistor question
    This came up at All Transistors Data Sheet site but you'll have to get someone to vet these as I can't translate it either.
    Code:
    Cross-reference Search Result (Equivalent Transistors)
    			 Mat		 Struct		 Pc		 Ucb		 Uce		 Ueb		 Ic		 Tj		 Ft		 Cc, pF		 Hfe		 Caps
    1.	2SA1200    Si 	 	 PNP 	 	     0.5 	 	 150 	 	 150 	 	 5 	 	 0.05 	 	 135 	 	 120 	 	 4 	 	     110 	 	 SP0
    2.	2SB1027 	 Si 	 	 PNP 	 	     10 	 	 180 	 	 180 	 	 5 	 	 1.5 	 	 175 	 	 	 	 	 	     150 	 	 SP0
    3.	2SB1028 	 Si 	 	 PNP 	 	     10 	 	 180 	 	 180 	 	 5 	 	 1.5 	 	 175 	 	 	 	 	 	     110 	 	 SP0
    4.	2SB1046 	 Si 	 	 PNP 	 	     1 	 	 180 	 	 0 	 	 20 	 	 0.05 	 	 165 	 	 	 	 	 	     160 	 	 SP0
    • mmartell
      • Oct 2013
      • 3189
      The formatting didn't come up very well.. Is the HT-RC560 the equivalent or sibling of the TX-NR626 ?
      • tibimakai
        • Jan 2012
        • 3680
        I don't have a 626 at this moment, but online, that is what people are saying, that is the same.
        Thanks for that list.
        • dolivas27
          • Mar 2014
          • 66
          These guys have it in stock and are in CA but have a $25 min might want to see if they have anything else you need.
          http://www.questcomp.com/questdetail...id=178955&pt=0
          • tibimakai
            • Jan 2012
            • 3680
            They are actually pretty close to me, but I don't think, that they sell over the counter.
            I think that I will use, what I have used in the 636: DXT5551DICT-ND, FCX555CT-ND.
            I will see how it will work.
            • dolivas27
              • Mar 2014
              • 66
              Diodes Incorporated shows this as an exact match for the 2SA-1200
              http://www.digikey.com/product-detai...96CT-ND/334756
              And this one for the 2SC2880
              http://www.digikey.com/product-detai...95CT-ND/334754
              Hope this helps.
              • tibimakai
                • Jan 2012
                • 3680
                I have put back, the 2SC2880-Y and I have used the FCX555CT in 2SA1200-Y's place and it seems, like it's working great.
                Another one repaired. This one, is pretty much the TX-NR626, under different name.
                Thank you for everybody, who helped.
                • MotherTeresa
                  Onkyo TX-NR5007 (NR3007 NR1007) NAND DUMP for DZKB4 DSP
                  by MotherTeresa
                  Hi.
                  I'm looking for a DSP NAND DUMP for the Onkyo TX-NR5007 that works with the DZKB4 chip. Can anyone help?
                  Regards.
                  09-20-2025, 12:09 PM
                • CDNBrewer
                  Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                  by CDNBrewer
                  Hello Everyone,
                  I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                  Symptoms:
                  • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                  • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                  • I swapped the Left and Right surround
                  08-05-2025, 09:29 PM
                • magneh
                  Behringer Eurolive B205D repair - help identifying transistor
                  by magneh
                  Hello
                  Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                  Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                  After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                  I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                  Still, I need to replace this transistor....
                  06-18-2025, 02:34 AM
                • FrancescoV
                  Onkyo HT-R390 no sound output, video output ok
                  by FrancescoV
                  Good morning everyone,
                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                  The firmware reported is the following:
                  M:1.00/11107BLP
                  D:?.??/????????
                  O:1.00/11107AL
                  The DSP firmware given the question marks seems corrupt.
                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                  05-11-2025, 02:59 AM
                • elsomer
                  help to identify transistor msi ms-15ck1
                  by elsomer
                  hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                  02-17-2025, 05:30 PM
