Texas Instrument chip on VSX-921-K AV receiver
  • holmzy
    • Nov 2009
    • 99
    Give us a help guys I'm trying to find out if this chip is faulty or not. It has test points around it but I'm self taught engineer and.....ok I'm just dumb. HELP!!
    Its dirty around it because I put flux and heat up but I'm not even sure if the chip works. The bruises on it were there before.
  • holmzy
    • Nov 2009
    • 99
    Re: Texas Instrument chip on VSX-921-K AV receiver
    woops didnt attach image before was too big
    • tibimakai
      • Jan 2012
      • 3680
      Did you look up the data sheet?
      • holmzy
        • Nov 2009
        • 99
        I could only find links to aliexpress.com. I nearly said alibaba lol
        • holmzy
          • Nov 2009
          • 99
          THERE IS A ALIBABA.com lol
          • mmartell
            • Oct 2013
            • 3189
            That could be the same series that was going wonky in many Onkyo receivers, can't tell from the pic though.
            • holmzy
              • Nov 2009
              • 99
              I am aware of that not sure what series they were. There must be a way to test it. I can see the test points on the circuit board. Has anyone got any ideas at all? willing to try anything pretty much!!
              • holmzy
                • Nov 2009
                • 99
                any input?
                  It's a DSP chip. Pretty hard to test. Handles all the fancy audio processing. I believe the service manual for Onkyo and Yamaha amplifiers (if yours is one of those) has ways to "bypass" this chip as part of the fault diagnosis process. Maybe worth taking a look?
                  • holmzy
                    • Nov 2009
                    • 99
                    Hi Mr.T I thought you only deal with TV's silly me! I tried fixing one of these got bored of TV's but have hit a massive brick wall with amps. I found the service manual but it might as well be in chinese. Also the dts chip is different. I wached a video online and the guy made the amp a pre out from the inside. I'm going to not only try that but also try to feed it a signal also and see if the amp actually works. I have a feeling none of them is going to work. but worth a try I guess. Will post updates.
                    • holmzy
                      • Nov 2009
                      • 99
                      should mention that it has no sound from analogue or digital or stereo or surround. but boots perfectly normally
                      • holmzy
                        • Nov 2009
                        • 99
                        I'm such an idiot forgot to mention its a Pioneer
                        • holmzy
                          • Nov 2009
                          • 99
                          update, looks like the amp section works perfect, well the left channel does. I attached my phone to left channel input to the amp section directly and one speaker. It worked but was low volume. the volume on the amp iself had no effect on sound nor did any source selections or surround modes. normal cd input still did not work.
                          looks like the issue is from input to the amp section. so from the input board to hdmi board.
                          any suggestions guys?
                          • holmzy
                            • Nov 2009
                            • 99
                            anyone?
                            • CapLeaker
                              Leaking Member
                              • 8168
                              That's kind of good and not. At least you know that the output stage is O.k. That nothing is working in digital and analog, tells you the problem is before that stage. No error indication is kind of weird, but maybe the problem is in the input stage. Maybe the input selector is bad? Try to see if you can feed it audio and get something back out on the REC side of the tape function.
                              Also look at page 53 of the service manual (ground points).
                              Page 16 and 17 show you the block diagram. Try to get the analog working (easier). I guess there is a relay that switches between analog and digital... see what that is doing? No DC on the RCA input jacks I hope?
                              • holmzy
                                • Nov 2009
                                • 99
                                wow thanks for the input! i will try in couple hours when my daughter sleeps and report back
                                • holmzy
                                  • Nov 2009
                                  • 99
                                  ok i could only try one thing. the input selector seems to work fine and select any input. all the display and selectors seem to work fine on the outside. i input from phone to tv analog left line in and attached speaker to left line out and did the source selection. then selected pure direct sound and no surround sound. no activity. pages 16 and 17 look very easy to follow (i hope) and will give that a shot first as the grounding thing seems complicated as i have to rip the whole thing apart i think.
                                  • CapLeaker
                                    Leaking Member
                                    • 8168
                                    I had no idea if the unit is together or apart. Some tare it apart, then wonder: why isn't it working? That why I mentioned the grounding thing.
                                    O.k. Seems like the selector is fine. It is always good to have a look at the block diagram first and get a bit familiar with things, before you go and dig into the big schematic.
                                    What happensd to the amp first place?
                                    • holmzy
                                      • Nov 2009
                                      • 99
                                      was given to me. he doesnt know what happened either. just stopped working. been so busy had not had time to look into it.
                                      i did have a look today and still getting nowhere. i did manage to find fl-out from the dsp board and it had no signal. its either the dsp/hdmi board or the 7.1 channel audio board with this chip on it bd3473ks2.
                                      im starting to think that its not the hdmi board mainly because when put amp in direct mode it by-passes the dsp stuff. but i could be wrong.
                                      • ericgonsalves
                                        • Jun 2015
                                        • United Kingdom
                                        Hi
                                        I am having a VSX-924-k with the same audio chip and also having the same issue. Checked the amp section and it is working fine but there is no input coming from the audio chip to the amp section. By any chance you managed to sort your problem.
