Alpine 3503 Car Audio Amp
  • linuxguru
    • Apr 2005
    • 1564
    Found two leaking Nichicon VZ 2200/16 in an Alpine 3503 car amplifier from the early 90s. Date Code on the caps is 9138 - probably 1991, 38th week. All other caps (mostly in the signal path and small bypass/bootstrap) were Elna RE2 and seem to be fine. The VZs were the main power supply bypass caps for the NEC chip-amps, and were leaking brown electrolyte from the lower seal - no bulging was seen. The unit was made in Taiwan, R.O.C, but all components seem to be Japanese.
    Replaced with Panasonic FC 1000/25 (anything larger was too tall, and I didn't have any suitable 16v caps lying around) and the sound improvement was dramatic - it's now better than new, with excellent tonality, depth and detail.
  • Kaine
    • Mar 2007
    • 55
    Re: Alpine 3503 Car Audio Amp
    that's great news
    I'm a big alpine fan, i'd love to see a shot of the internals if you happened to take any
    • tvtech
      • Oct 2006
      • 48
      Its common for those older nichicon capacitors to leak and go open.The rubber seal on the bottom rots and the electrolyte leaks out corroding the circuit board and other components.If there are any more black nichicon capacitors in that amp I would also replace those because if they aren't already leaking they will be soon.Ususally the dark blue case nichicon capacitors aren't affected by this problem and would leave them alone unless you suspect they are bad.Keep an eye on those elna caps too because certain series are know leakers,they caused lots of problems in the vertical and audio output sections of older toshiba tv's
      • DrewPhillips
        Capacitor Diarrhea - Nichicon PL Series
        by DrewPhillips
        Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
        The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
        03-02-2025, 10:18 PM
      • nick3092
        Mid/late 80's Nichicon Yellow Caps
        by nick3092
        I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
        08-28-2022, 03:56 PM
      • Spudgun
        Why doesn't current just bypass faulty capacitors.
        by Spudgun
        Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
        04-01-2025, 10:33 AM
      • chth96
        Is there datasheet for nichicon LXJ series?
        by chth96
        I want to calculate capacitor ESR referring to below guide.
        https://forum.digikey.com/t/calculat...-from-tan/2633
        I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
        I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
        Is there anyone who still has old nichicon datasheet which has information of LXJ series?
        11-20-2022, 08:11 AM
      • chth96
        Is there any datasheet for nichicon RT(M) series?
        by chth96
        A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
        https://www.badcaps.net/forum/troubl...e-been-blew-up
        and I finally fixed​ this retro game console by soldering varistor and glass fuse.
        But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
        I have spare console...
        11-28-2023, 03:36 AM
