SONY CMT-EH10, HCD-EH10 CD/TUNER/DECK -shuts down on boot up back to standby
  • tw2005
    • Oct 2011
    • 6458
    The old man had a SONY CMT-EH10, HCD-EH10 CD/TUNER/DECK -shuts down on boot up back into standby. seemed like some kind of protection, after first powerup, shut down a lot quicker. had a hunch bad caps but not 100% sure, after opening it up nothing visual but crap caps used.
    All 85 degree lelon and FOAI caps, nothing bulged but only about 16 caps so recapped the whole board.
    Fixed the issue, don't have a ESR or Cap meter but quick check of what was removed I had 1 x FOAI 1000uf 16v cap dead short, and a 220uf 10v ca-p with low resistance.
  • brithepi2k
    Sony KD-65XE8596 no standby light
    by brithepi2k
    I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
    cheers...
    09-06-2025, 02:22 PM
  • rabbituk
    Sony HCD BX7700dbi CMT flashing standby
    by rabbituk
    I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
    So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
    02-11-2025, 05:05 PM
  • tec3000
    Sony LED 65X9005A shuts down after few seconds - looking for help
    by tec3000
    Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
    I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
    03-20-2024, 07:29 AM
  • goodpsusearch
    Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
    by goodpsusearch
    Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
    First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
    05-05-2024, 02:04 PM
  • androripara
    Sony Bravia 55HX820 - 4 times blinking red standby led
    by androripara
    i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
    I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
    Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
    10-19-2023, 05:16 AM
