LG SN9YG Soundbar - Stuck with Please Wait
  • pauldow
    • Oct 2012
    • 92
    • US
    Another dump find, so someone must have given up on it already.
    The list price was $700, so I figure it's worth giving it a try.
    When I plug it in, the display briefly says Hello, then the volume level, the scrolls Please Wait. There are 4 LEDs under the display words that go in a three second loop of 2 inner on, all 4 on, all 4 off.
    From the remote, the volume level changes on the display, but that seems to be the only activity.
    The owners manual says to hold the microphone mute button for 5 seconds to reset, but nothing there.
    I located a service manual for a similar item (SL8YG), and it has a procedure to check the software versions by pressing and holding a settings button, but no change there either.
    The service manual does give instructions on how to update the software, but it has no reference of where that can be obtained. Is the software available?
    Thanks,
    Paul
  • Daniel Larsson
    Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
    by Daniel Larsson
    My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
    I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
    During these seconds the function button is not working...
    08-13-2025, 10:29 AM
  • Stunt
    Hp Laptop Stuck on Hp protected by hp sure start screen
    by Stunt
    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
    screen that's it and stuck there. I left it until the following day and i still...
    09-02-2025, 01:51 PM
  • paulxxxx
    Vizio E701i-A3 stuck at logo, need service manual
    by paulxxxx
    The TV stuck at logo and cannot be turned off unless the cord is unplugged.
    I was given two main boards and exactly the the same thing happens to both of them.
    I have checked all voltages on the connector on the power board that goes into the main board and they all look OK.
    There are no signs of damage on any of the 3 boards.
    Would someone help me with a pointer to the manual? It's supposedly to be the same as E601i-A3.
    Thanks!
    09-08-2023, 01:11 PM
  • stormanimal83
    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
    by stormanimal83
    Hey....
    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
    01-18-2024, 02:15 PM
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
