Onkyo-593 No power and now clicking sound
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Check again d901 in diode mode for short (I do not remember by heart the internal schematics of the bridge rectifiers, so I test each pin to each other pins, then switch the probes and again).
    You can use IPA to find the hot component(s) - drop IPA on the component and see how fast evaporates.
    Thermal print labels also can be used - cover area with a label and see where it will get black.
    This power rail doesn't have too many common points to ground - q502, d516, q501, q434+q436... all other possible paths include too many components that have to be shorted. So try injecting voltage again and check that components if they are getting hot.
    • Sisko
      • Apr 2020
      • 25
      Hi there.
      Ok I checked d901 in diode mode and no shorts I even took the time to take it out and recheck it just to make sure and it's OK. So while the d901 was out I decided to do another
      voltage injection just in case and again no hot spot any where.
      Ok decided to recheck q901 if it was working and it is faulty will not give 12v output under a 14.5v on my bench power supply, I get 0vdc on the output. So will need to reorder one again. Again no more short on c902 when q901 isn't there.
      THANKS!!!
      • madan1
        • Nov 2016
        • 726
        • Bulgaria
        If the short is gone, you can try powering up the unit (without q502 and q901). Preferably through a dim-bulb tester, but even without, looks like the smps ic has a working protection and a test should not do more harm.
        A good result would be stable power rails (stable voltage on c905, c902 c901 c911 c912).. from the schematics and the smps documentation, looks like the smps IC supports low and high power modes, so not really sure what should be the voltage.
        • Sisko
          • Apr 2020
          • 25
          Hi there.
          Ok plugged the power up and the dim-bulb lit very briefly and I heard a very faint click then a small buzz that doesn't stop, I checked c901 and it started at 32v but voltage getting high fast and not stopping at all , c902 no voltage at all.
          I didn't check any other caps because of the buzzing noise and didn't want to burn anything else. I should get my part q901 tomorrow. What would be the normal voltage at c901 there isn't anything on the shem that says what voltage?
          Thanks!!!!
          Sisko
          • madan1
            • Nov 2016
            • 726
            • Bulgaria
            That's the smoothing caps on the primary getting charged.
            Is the buzz coming from the transformer(s)?
            I checked c901 and it started at 32v but voltage getting high fast and not stopping at all , c902 no voltage at all...What would be the normal voltage at c901 there isn't anything on the shem that says what voltage?
            Did it exceed 40-45V?
            Manual says, according to the model, it should be 30 or 40V (+/- few volts)
            On c902 the voltage should be same but with opposite polarity.
            If there is no voltage on c902 you have the following options:
            there is short on that rail
            d901 is bad
            the transformer is bad
            It would be interesting to know if the 12v rails are present (c921/c911 and c922/c912)
            • Sisko
              • Apr 2020
              • 25
              d901 is bad
              Hi there
              Ok tested c911 and it has 12v, c912 0v, c921 9.10v and c922 0v. Ok rechecked c901 and it goes beyond 40v and not stopping. D901 was tested before I put it back and it was good.
              I wanted to say that this amp has a protection mode circuit (in red on pic that I have provided) and wondered if it's why I don't get any voltage at c902? As I can see IRS2092 (q501) is part of this "protection"
              circuit and I have 2 new ones IF ever I need to change this part. I got my q901 parts (got 2) today.
              THANKS!!!
              Sisko
              • madan1
                • Nov 2016
                • 726
                • Bulgaria
                #27
                Not having the -12V rails is no bueno. It is tapped into the transformer before D901.
                At this point I can figure out only two reasons for not having the negative rails - dead short on one of the rails or the transformer winding for the negative rails is gone.
                The protection circuit switches off the smps IC on the primary side by shorting VREF to DIS with opto Q955. Usually this is triggered by overvoltage, undervoltage, over-current and high temp.
                One last try before focusing on the transformer - desolder d901, d912 and d911. This will disconnect the transformer windings from the main power rails.
                After that check for short on c912 c912 and again c901 and c902. Do not solder them back before fixing the short.
                And while you are there - check c903 for short and r901 for correct value (6.8ohms)
                • Sisko
                  • Apr 2020
                  • 25
                  Hi. I forgot to say that I have checked c904 and had around 38v and -38v.
                  • Sisko
                    • Apr 2020
                    • 25
                    Hi there
                    Ok checked R901 got 10.7 Ohms, c902 getting short on + and getting reading on -, c901 getting reading on + and short on -, c911 getting reading on + and getting short on -, c912 getting short on + and - (but - doesn't beep), c903 no short on either + or -.
                    THANKS!!!
                    Sisko
                    • Sisko
                      • Apr 2020
                      • 25
                      Hi there
                      Ok rechecked the r901 out of circuit and I get 7.4 Ohms the other time it was still soldered on (yeah my bad).
                      • Sisko
                        • Apr 2020
                        • 25
                        Hi there
                        Ok I did answer this question a few message back and didn't get any reply as of yet, anything else to test/try? So waiting for your answer on what to do next.
                        THANKS!!!
                        Sisko
                        • R_J
                          • 9638
                          Why are you checking R901, you should be checking R912, if you have no -12vdc R912, L912 or D912 are likely open. Or the transformer winding between pins 8 and 9 may be open.
                          R901, C903 will not cause this fault, my guess would be open L912
                          • Sisko
                            • Apr 2020
                            • 25
                            Hi and thanks for your answer! Ok I was told by Madan1 to check r901 (check c903 for short and r901 for correct value (6.8ohms)) and that's what I did.
                            As I said to Madan1 I don't do electronic repair regulatory so I'm not used to do something as deep as this one here BUT I've always love fixing electronics since I was a kid but never had the time to really do the
                            deep stuff like this one, I just do this 1-2 times a year so it's a bithard for me to learn "how" to locate the problems. At first I thought this would be a fuse blown but it isn't so decided to dive in and try to fix this anyway
                            and give me a chance to "learn" as I go. So please I ask you to just understand my situation, I know this is easy for you as you can see all of this and understand what could be the problem but for me yeah it's a bit
                            hard BUT I'm determined to try to fix this but with some help and guidance and patience.
                            Ok Madan1 told me to remove d911 and d912 and before this I still have D901, Q901 and Q502 removed and If you have red my previous messages there was a short on C902 while Q901 was soldered there. Ok
                            what do you want me to do here to put back the D911 and D912 back and check voltage?
                            THANKS!!
                            Sisko
                            • R_J
                              • 9638
                              I did not know that you had parts removed when you did this test, with D911 and D912 you would not get the + or - 12v. You seem to have more than one problem; I was just looking at the missing -12v on C912 that you posted.
                              • Sisko
                                • Apr 2020
                                • 25
                                Hi and thanks for your reply! How can I attack this 2 problems? Can you help me a bit with this or give me any suggestions?
                                Thanks!!!
                                Sisko
                                • Sisko
                                  • Apr 2020
                                  • 25
                                  Hi all just wanted to say that I have decided to terminate this repair since itโ€™s been hard to find the problem and like R_J said that there could be more than just 1 problem so with this said Iโ€™ve decided to stop trying to fix this amp. Still I want to say a BIG THANKS to Madan1 for his help in this and Iโ€™m sorry if I may have had problems understanding your test requests. Again THANKS!!!๐Ÿ˜Š๐Ÿ‘
                                  • B0r1s
                                    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                    by B0r1s
                                    PSU - BN44-00878A
                                    Symptoms:
                                    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                    A weak clicking sound was coming from the transformer.
                                    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                    Progress:
                                    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                    01-17-2023, 04:58 PM
                                  • slimmy182
                                    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                    by slimmy182
                                    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                    Looking on google I found this:...
                                    01-14-2023, 11:55 AM
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • Solvik
                                    XFX XPS 650w 3XS PSU making Ticking/clicking sound
                                    by Solvik
                                    Hello
                                    i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                                    All voltages are normal....
                                    02-13-2025, 02:43 PM
                                  • nbnb
                                    Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                                    by nbnb
                                    I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                                    Any idea what is causing the clicking sound? Any easy way to...
                                    11-23-2019, 12:03 PM
