JBL PARTYBOX 1000 NO sound NO 50V
  • AlexVG
    • Apr 2022
    • 138
    • SPAIN
    Hi, I would like to share my experience...
    So, I came across with common problem - no 50V on PSU 40-PF0750-PWD1G
    L6566B was burned. Between pin 7 and GND were short circuit. I replaced L6566B with a new one, but it gave me nothing. However, it started if I touched pin 16 with multimeter probe. Obviously the protection is triggered.
    If we look at the L6566B datasheet, we will see that to deactivate the protection (AC_OK), is enough to exceed 0.450 volts.
    In my case, I have had 0.632 volts. This is enough at the first glance. But on the oscillogram on pin 16, I observed noise pulses an amplitude lower than 0.450 volts.
    I guess the problem is in reducing the voltage of the PFC where I have 376 volts. The JBL PARTYBOX datasheet indicates that 390V plus/minus 4.5 percent is acceptable. In my case, 376 volts is in permissible limit.
    Despite compliance with the parameters of the lower level, due to a decrease in the quality factor of the quenching capacitors, we have protection triggered.
    My solution:
    I replaced capacitors C32 and C36 with better ones.
    I slightly changed the divider (R69,R78,R80/R87) to get a confident excess of the protection threshold. I set 1.1 volts.
    There is another option to increase the PFC to 390 volts, but I left this option for you ))
    I attached a scheme where I measured important voltages.
    Good luck.
  • zyklop
    • May 2021
    • NRW
    Hello, i am not able to download the above file with error "Invalid File Specified"
    maybe i do something wrong ? Has onyone the file and could provide me as PM pls.
      • 31250
      confirmed - the link is broken
      • AlexVG
        • Apr 2022
        • 138
        • SPAIN
        Moment...
        JBL 1000 explanation 50V.pdf.zip
        Works now.
        I put it in zip-format
        • AlexVG
          • Apr 2022
          • 138
          • SPAIN
          Hi ZYKLOP,
          You should change the divider (R69,R78,R80/R87) to get a confident excess of the protection threshold. I set 1.1 volts.
          • zyklop
            • May 2021
            • NRW
            Many thanks, do you already know the values you used ?
            • Hw31
              • Aug 2021
              • 37
              • Ami
              Could you please link, what components you used?
              • AlexVG
                • Apr 2022
                • 138
                • SPAIN
                Sorry, I don't understand your question.
                  HP EliteBook 1050 G1 + LG SJ2 Bluetooth Sound Bar Notebook 1000 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 1050 G1 + LG SJ2 Bluetooth Sound Bar Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + LG SJ2 Bluetooth Sound Bar boardview and 1050 G1 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-06-2024, 02:34 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • LEECH666
                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                  by LEECH666
                  Good day ladies and gentleman!
                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                  01-19-2024, 05:46 PM
                • u666sa
                  HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                  by u666sa
                  Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                  Platform: ipa32 la-m024p rev 1b
                  Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                  I found a short on the other side:
                  10-04-2025, 05:03 PM
                • Christos Tsiligiannis
                  Marian Trace Alpha sound card repair help
                  by Christos Tsiligiannis
                  Hello to the forum.
                  My name is Christos, I am new to the forum here and i am posting from Greece.
                  So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                  To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                  So i tried asking for a schematic from the company and they would not give me one. Instead they...
                  11-18-2024, 05:26 AM
