Soldered WLAN module replacement, any catch ?
  • ss45
    • Jun 2019
    • 119
    • Brazil
    Hi guys
    ive got spectre 15 with WLAN module soldered
    in the windows device manager the device gave error 10 code.
    It is a common complain, user has to shipped the laptop back to HP for service since its a hardware problem. disabling reenabling or reinstall driver didnt help
    Can i easily order new WLAN module of the same model (Ax201),
    unsolder the damaged one, then solder new one onto the board ?
    Is there any ROM programming involved ?
    For reference the module looks like this onboard
    https://www.notebookcheck.net/filead...0d8d54b11e.jpg
  • ss45
    • Jun 2019
    • 119
    • Brazil
    Re: Soldered WLAN module replacement, any catch ?
    bump
    anybody with experience with replacing soldered wifi module on laptop ?
    was it an easy desolder then solder new module kind of job ?
    • CeeEee4
      • 43
      • EU
      Hi
      Were you able to successfully replace the Wi-Fi module? I have the same issue.
      Can anybody share some tips with replacing onboard Wi-Fi module thanks.
      • mon2
        • Dec 2019
        • 14589
        Code 10 is a bios enumeration fault and unable to allocate the proper resources.
        Test with the latest bios. Voice your issues with their technical support team. Poor coding of the bios. Been there and corrected such faults with HP and Dell. Then received a call from Dell legal to insist we remain quiet to avoid being sued. Crapware.
        • r3vsEngIT
          ALPS Electric BT/WLAN Combo Module Experiment
          by r3vsEngIT
          i have a 2017 volvo that i upgraded the stereo in but the week link now is the SBC codec the head unit uses to transmit audio. i took the unit apart and we have a UGKZ2 combo module with a CSR8311 bt chip. after some research it is my understanding that ALPS made another combo module that used the CSR8350 chip. this chip is capable of aptx. https://vehicle-electronics.biz/cont...s-alps-modules
          my question is, would it be possible to swap out this UGX module as plug n play? what about replacing the CSR chip itself? any idea where to get either?
          03-06-2025, 11:11 AM
        • badcapjerboard
          Soldered ram replacement Lenovo Slim 7 14IRP8
          by badcapjerboard
          I have a board with two of four ram chips bad. I believe the configuration is 4x4GB
          My question is can I replace all four chips with a larger size, say 4x8GB of the same chip model and will it be recognized without modifying the motherboard and/or bios? Is it doable without being able to find schematics?
          Lenovo Slim 7 14IRP8 - Type 83A4 E239218 2305 C-03
          Ram says: K3LKBKBOBM MGCP SEC 249 BHU14149P
          05-07-2025, 03:37 AM
        • AlexVG
          Replacing the WiFi module on a vacuum cleaner iROBOT i7
          by AlexVG
          I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
          I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
          (This board does not respond, only the LEDs light up in a circle.
          The liquid damage is catastrophic and restoration is impractical).
          (I bought this board to get the WiFi module and camera).
          The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
          If...
          10-22-2024, 07:20 AM
        • japlytic
          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
          by japlytic
          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
          Tried (only with keyboard/mouse connected):
          • BIOS + database update
          • Using latest Windows 11 image built with official image creation tool
          • Previous setup version for Windows 11 installer
          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
          06-19-2025, 04:59 PM
        • clmorre
          wireless module not supported wlan module id 702
          by clmorre
          Can someone help me regarding "wireless module not supported wlan module id 702"?
          board code is da0ax2mb6f0 rev f
          Is it possible to edit the bios?...
          01-05-2021, 01:10 AM
