Yamaha DXR15 Powered Speaker Fault LED On
  • MobileXT
    • Oct 2012
    • 214
    Another updates: I install the parts I get sound but another problem. I don't have high I test the tweeter is good.
    • CapLeaker
      Leaking Member
      • 8342
      check if there is audio going to the TDA8922. Maybe the mute is on somehow, no VSS, no oscillator, something open in the output, etc.
      • R_J
        • 9608
        Originally posted by MobileXT
        I have a shorted on the IC713 and IC715 both on PIN 6 & 7 so I ordered the parts from Mouser NJM2068M-D hopefully will get here by next week. Once I get the parts I will update you guys.
        IC713 has a 0Ω resistor (R897) across pins 6 & 7, IC 715 pin 6&7 are connected together (section of ic not used)
        • MobileXT
          • Oct 2012
          • 214
          That's what I thought it could be mute somewhere so I am looking at Q256 and Q257 as well as the IC724.I am still waiting for my oscilloscope. I already did replaced the TDA8922 that from China it could be faulty that's why have the same problem no audio output.
          • MobileXT
            • Oct 2012
            • 214
            I check the Audio output at IC724 at Pin 1 and Pin 7 and I don't get any audio output. I did also replaced the IC724 and still have the same problem no audio output. The power supply is okay I have +15v at Pin 8 and -14.84v at PIN 4 Look Like DSP IC702 is no audio output at PIN 34,33 & 35 ,36 . I do have audio output @ PIN 29,30 & 31,32 which is the LF output.
            • MobileXT
              • Oct 2012
              • 214
              No Audio going to the the TDA8922.
              • CapLeaker
                Leaking Member
                • 8342
                Oyyy… it went as far as the DSP? Dayum! That sux!
                • MobileXT
                  • Oct 2012
                  • 214
                  Updates: I replaced the the DSP IC702 from mouser.com and still have the same problems. Still no audio going out to the HF. So the problem is not the DSP IC it could be on the input but I do have output for the LF. Is not the Amp board because I installed the brand new one. Any suggestions greatly appreciated.
                  • CapLeaker
                    Leaking Member
                    • 8342
                    This doesn’t make any sense to me. If no HF is coming out of the DSP, it’s either damaged, not programmed or something turned off. I suppose you could disconnect some traces and jumper in the LF out of the DSP over to the HF. Usually you just can’t swap a DSP out and call it good. It needs to be programmed or a firmware update done. The HF enable is having the same status as the LF enable (PA boards)?
                    Problem can’t be in the input if LF is working. Look at the diagram.
                    • MobileXT
                      • Oct 2012
                      • 214
                      I know this is not make sense to me either. I was planning that too jumper from the LF I plan to removed the IC724 and run a jumper. Yes! you can replace the IC702 without programming because I did that with my other speakers and working good so far and everything working HF, LF and D-contour. The IC701 is the one controlling all the programing into this DSP. So I am guessing that the IC701 is also defective but this one need to re-program for sure. So my last options is to run a jumper from the LF to the HF.
                      • MobileXT
                        • Oct 2012
                        • 214
                        I am also planning to swap the DSP from the DXR10 to DXR15 since the DSP have all the switch to specific switch to every model. IF I swap the DSP from the DXR10 and turn-on the switch from DRX10 to DXR15 model. What yo guys think?
                        • madan1
                          • Nov 2016
                          • 726
                          • Bulgaria
                          #32
                          Do you have to correct sw701 settings and "model type resister" value on pin30/ic701? I guess if the CPU thinks it is a subwoofer, it will not output any HF signal from the dsp..
                          Should work even without changing the switch settings.
                          • MobileXT
                            • Oct 2012
                            • 214
                            Thanks madan1 I will look into that one but for sure I didn’t touch the sw-701 before but it’s good to know maybe I can turn on turn off the switch 701 maybe some bad connection there. Thanks for confirming the DSP board swap from Dxr8,10 or 12 to dxr15 that will work I don’t have the parts right now but definitely I will look forward on this options and I saw some parts online for the dxr series for parts.
                            • CapLeaker
                              Leaking Member
                              • 8342
                              I think you got lucky there. Usually DSP’s including this one are programmable.
                              • MobileXT
                                • Oct 2012
                                • 214
                                I think I found the Problem on the RA711 Pin7 3v3 PIN 8 3V, PIN5 3V3 PIN6 3V, PIN3 3v3 PIN4 0V, PIN1 3v3 PIN2 0v. Where I can get this array resistors I try google I can't find anything mouser & digit key the parts number is WH211800.
                                • madan1
                                  • Nov 2016
                                  • 726
                                  • Bulgaria
                                  #36
                                  pin2 and pin4 might be pulled down through sw701 and/or r713 and r811. Switch off the unit and measure the resistance on each resistor of the array.. it should be 10k. If there are open resistors from array, try placing good ones just on their place.. it should not be hard - one end is on 3.3v power rail, the other on the slide switch.
                                  p.s. if you insist on the exact part - just google "resistor array smd 4*10k"
                                  • madan1
                                    • Nov 2016
                                    • 726
                                    • Bulgaria
                                    #37
                                    By the way, check for short to ground and audio/analog signal on pins 12 13 14 15 and 33 34 35 36 on IC702
                                    Also check for audio/analog signal on pins 4 5 24 25 on IC703. Check same pins for short to ground.
                                    • CapLeaker
                                      Leaking Member
                                      • 8342
                                      Naah,that’s not it... That’s for the model selector switch on the main IC. Keep looking,
                                      • MobileXT
                                        • Oct 2012
                                        • 214
                                        Another updates: I received my complete donor for DXR15 amp so I removed the tweeter amp and replaced my old one and now everything is working now two speakers back to life. So Now I like try to fix the donor amp that the problem was not turning on. No green lights missing the -55V and +55V. Also want to fix the tweeter amp. But I like try to fix the AMP board first then the tweeter amp.
                                        • CapLeaker
                                          Leaking Member
                                          • 8342
                                          Check across C137 and C138 for a short. If no short, go backwards to Q106, and then the PWM IC101. Since you got a full working set, you can use it to compare readings.
                                          • sukaht
                                            Yamaha MSR400 - Powered PA Speaker
                                            by sukaht
                                            Hello everyone.
                                            I need help with my Yamaha MSR400 - Powered PA Speaker that I bought it used recently.
                                            It is power on, and sounding good / working perfectly fine. However after 3 - 5 minutes, the heatsink is starting to get warm, and it smells burning a little bit.
                                            I did tried multiple times on different day, event the speaker is not playing any song (input does not connect to any source, and the volume level is zero), after it turns ON, 5 minutes later, the heatsink is starting to get warm, and it smells burning a little bit. I am afraid keeping it ON longer than 5 minutes...
                                            11-02-2024, 07:55 PM
                                          • GerryT
                                            Electro Voice SXA series 100 or 250 powered PA speaker Schematic needed
                                            by GerryT
                                            Does anyone happen to have a schematic for the amplifier for an Electro Voice SXA series 100 or 250 powered PA speaker?
                                            09-17-2023, 10:12 PM
                                          • JimBanville
                                            Switched speaker impedance selector w/ Yamaha HTR-5740 RX-V450 powered on!! Problem?
                                            by JimBanville
                                            So I didn't realize there was a tiny written warning on the speaker impedance switch on the back that said moving the switch with the power on "may damage the unit". I actually switched it multiple times, listening for any possible audible changes. It wasn't until later I saw the tiny warning. I haven't noticed any issues though. Can someone please look at the schematic and tell me what damage I may have caused? Thanks!!...
                                            01-25-2021, 08:45 AM
                                            Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                            Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                            various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                            Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                            trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                            what is wrong with your PC in just seconds. It saves you time and money.
                                            Our new and improved design...
                                            11-01-2024, 06:29 AM
                                            HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 02:30 PM
