I assume this first one B50K would be ok to put in place of those two, right ?
Behringer xenyx x1204usb mixer
This topic has been answered.
Can I use that AC10K instead of B503 6pin ? They are both without center pin.
B50K link is now giving me 404 errorComment
ah, I will need new AC10K then with midpoint because this was for some reason without midpoint(center). I'll try and search it myself if you don't have time.Comment
I searched now on aliexpress but I can't find anything with midpoint AC10K 6pin 23mm shaft.
does it matter if there is no midpoint, will it work normally without it if I put them instead of this original ones ?Last edited by Thermaltake; 04-10-2025, 02:31 AM.Comment
Lol... The pot with or without the midpoint is exactly the same electronically. The little click is only guidance for extremely low light conditions or blind users... electronically there is no difference....
Just use the correct values in the correct places...Comment
by LongonHi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
by ThermaltakeHi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.-
by dicky96Hi guys
I have this faulty mixer here. Basically the owner says it worked fine at one gig, then the next one it didn't
When I power on, both the L & R LED Meters go to +4 and stay there. This is without any input and with all sliders Level Set knobs set to zero
Also the LED meter on the 24-bit dual engine DSP goes to red (clip)
I didn't connect an speakers but if I use headphones I can hear what I can best describe as a purring noise on both channels
I found a schematic for the PSU There is a 10 way ribbon cable going from the PA/PSU...-
by BektronicsHello dear audio friends.
I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
Thanks in advance if anyone can help me with this schematic.
Of course, all information about this digital mixer and possibly references...-
07-24-2023, 06:40 AM -
by ThermaltakeI am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
I google a little and found that there is this part number... - Loading...
