Behringer xenyx x1204usb mixer
This topic has been answered.
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 339
    • D12
    Originally posted by check12
    Then you need to list the serial numbers on each pot and also the number of pins... I am not telepathic... 😵‍💫
    I finally manage to disassemble the mixer.
    All pots have 1,8cm shaft measuring only plastic part. From metal part of pot to top of shaft is 2,3cm
    Here are mark of all pots inside mixer:
    For headphones - B503DC (6 pin)
    For FX With central pin - B503x (3 pin)
    For Balance With central pin - AC103w (6 pin)
    For low, mid and highs With central pin - B503w (6 pin)
    If someone can help me to pick some high quality pots to replace them with this behriger garbage ones. Thanks
    • check12
      • Nov 2012
      • 142
      Just saw this ... haven't got time right now but tomo evening maybe ... I'll post the values etc. unless someone else does it first ...
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 339
        • D12
        Thanks!
        If it's possible for shop to be in EU, to avoid extra VAT to pay.
        • check12
          • Nov 2012
          • 142
          For headphones= Search Google for "B503 linear 50k ohm vertical no detent dual 6 pin pot“
          For FX= Search for "B503 linear 50k ohm vertical center detent 3 pin pot"
          For low, mid & high EQ= Search for "B503 linear 50k ohm vertical center detent dual 6 pin pot"
          For balance (pan?) = Search for "AC taper 10k ohm vertical center detent dual 6 pin blend pot"
          AC taper blend pots can be difficult to find but don't often need replaced.
          There's no way I have time to search for where you can get the cheapest parts, you will have to do that yourself... I have provided what to search for.
          Pots made by Bourns, Alps, Alpha (Taiwan)... are the kind of product you are looking for.
          If you are unsure about what you find then post the links where you want to buy and I or others will confirm if suitable.
          • Thermaltake
            Brain badcap
            • Aug 2015
            • 339
            • D12
            Ok, I'll try to find them in few days and post links for you to confirm if I pick right ones, thanks!
            Can you tell me just am I searching for shaft 18mm or 23mm ? How is it measure from metal part or just plastic thing ?
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 339
              • D12
              #26
              Forgot one pot
              It's also FX central pin - 3B503x (6 pin)
              Another question
              If I want to change caps on motherboard of mixer, do I need to put low esr caps or normal caps ?
              • check12
                • Nov 2012
                • 142
                Forgot one pot
                Another question
                Use the same replacement pot as low, mid, high EQ.
                Easiest way to replace caps in behringer power supply is to use 105c (temperature) low esr for all replacements.
                IMO your doing a lot of unnecessary work... What is actually wrong with the desk?
                • check12
                  • Nov 2012
                  • 142
                  For confirmation can you post a photo of the 3B503x pot... I want to make sure it's a vertical pot?
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 339
                    • D12
                    #29
                    Caps on PSU were already replaced a year ago. There were 3 bad caps, and I replace them all with stronger ones few Volts more than it was by factory. I was talking about motherboard where pots are, when I am going to replace pots I would like to replace that caps also and for them I was asking if they are low esr or normal caps.
                    I noticed there are two kind of 3B503x (both for FX/AUX and both with central pin.)
                    1. https://i.imgur.com/Tuqxtd2.jpg
                    2. https://i.imgur.com/1lrWuTm.jpg
                    • check12
                      • Nov 2012
                      • 142
                      Caps on the main pcb should not need replaced.
                      OK photos confirm all pots are mounted vertically so what I advised in reply #27 is correct.
                      I'm taking it when you say "central pin" you mean you feel a little click when the pot shaft is in the middle of the range of travel? e.g. Half way between fully CCW & fully CW?
                      • Thermaltake
                        Brain badcap
                        • Aug 2015
                        • 339
                        • D12
                        #31
                        Ok.
                        Now I see, stupid me. The difference is one is 6 pin, one is 3 pin, that's why they're different.
                        Yes central pin when you move pot in the center there is click or stop however you want to call it.
                        • check12
                          • Nov 2012
                          • 142
                          Ok.
                          Yes the only difference is the amount of pins, these pot serial numbers are just behringer part numbers ... e.g. for the 3B503x the "3" and the "x" are likely just added as part identifiers for behringer, the important details are:
                          the B = linear taper
                          the 503 code = (which means 50 followed by three zero's) = 50,000 ohms or 50k ohm
                          ... then you also do a visual & manual check to find:
                          the pot mounting orientation = vertical
                          the number of pins = either 3 or 6
                          the length of shaft & size of body
                          & finally ... whether the pot has a tactile center detent or not
                          • Thermaltake
                            Brain badcap
                            • Aug 2015
                            • 339
                            • D12
                            #33
                            Thanks so much for all the info. and patience for explaining
                            • Thermaltake
                              Brain badcap
                              • Aug 2015
                              • 339
                              • D12
                              #34
                              Sent mail few days ago to TME with all the values of pots I need, and they told me today " Hello! We can't to offer.... 🙁​ " So I guess I am continuing to send mails and finding out who can provide me those pots.
                              • Thermaltake
                                Brain badcap
                                • Aug 2015
                                • 339
                                • D12
                                #35
                                Can someone help me with getting this pot's, everyone that I contact can't help me...
                                • check12
                                  • Nov 2012
                                  • 142
                                  B503 = B50K (6pin with midpoint) use for headphones, low, mid, high EQ = https://www.aliexpress.com/item/1005007954345312.html
                                  B503 = B50K (3pin with midpoint) for FX = https://www.aliexpress.com/item/1005005806597186.html
                                  AC103 = AC10K (6pin with midpoint) for "balance" = https://www.aliexpress.com/item/1005006950880734.html
                                  I know the original headphone pot did not have a midpoint detent but having one will make no difference.
                                  Don't forget to choose the correct "AC10K With Midpoint" option in the listing for the AC103 pots ...... & in the 3pin B50K listing choose "50 ohm" option, they have forgotten to type the K (it shows the pot with the K in the photo & they don't make that style of pot in only 50 ohms).
                                  The B50K are all Taiwan Alpha pots which are good quality, the AC taper pots are difficult to find so you'll just have to go with what's available.
                                  I've no more time for this so if your not happy with these links then you will have to search further for yourself ... all the info for searching has been given...
                                  • Thermaltake
                                    Brain badcap
                                    • Aug 2015
                                    • 339
                                    • D12
                                    #37
                                    Thanks.
                                    On B50K - this one on link have plastic threads on the bottom of the pot. Mine don't, and I think that will make problems when I wan't to close that metal cover of mixer.
                                    • check12
                                      • Nov 2012
                                      • 142
                                      Thanks.
                                      OK didn't consider that and actually I think I have advised wrong base size for the pot frame snap in lugs.
                                      Post the measurements (length, width) of the square pot bases & I'll have a look again when I've got time... 👍
                                      • check12
                                        • Nov 2012
                                        • 142
                                        Ok corrected list ... (taking it that the 6pin pots are 12mm between the 2X "snap in" securing tabs on the pot bases) that's the most common size:
                                        B503 = B50K (6pin with midpoint) use for headphones & low, mid, high EQ = https://www.aliexpress.com/item/1005007343612656.html
                                        B503 = B50K (3pin with midpoint) for FX = https://www.aliexpress.com/item/1005006554255808.html
                                        AC103 = AC10K (6pin with midpoint) for "balance" = https://www.aliexpress.com/item/1005008338040792.html
                                        Always click on postage options and choose "Aliexpress standard delivery" and you should receive them within 14 days ... other options can take months...
                                        These are all from the same trader you might get a cheaper deal by contacting them and asking for consolidated postage ... (Always use Aliexpress standard delivery though)...
                                        • Thermaltake
                                          Brain badcap
                                          • Aug 2015
                                          • 339
                                          • D12
                                          #40
                                          Thank you.
                                          There also 2x 3B503x with 6 pin and midpoint for FX on the Stereo Aux Returns.
                                          • Longon
                                            Behringer Pro Mixer DJX-750
                                            by Longon
                                            Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                            08-11-2025, 02:17 PM
                                          • Thermaltake
                                            Power button on Behringer Xenyx 1204USB mixer dead ?
                                            by Thermaltake
                                            Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
                                            I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
                                            08-16-2022, 03:22 AM
                                          • mon2
                                            EFX12 Mixer repair
                                            by mon2
                                            Hello. Curious if anyone here has worked on the Soundcraft EFX12 mixer repair? Not convinced if are dealing with an original Soundcraft unit or a high copy of the original. The offshore market appears to have cloned this unit - tons on Aliexpress / Alibaba.
                                            The public schematics of the EFX12 from Soundcraft do not match the board we are servicing. After some review, have serviced most of the defects and noting a defective gain control potentiometer. Would anyone know of the value? From some internet searches, appears to be a C10k = 103 = 10k ohm reverse log pot with a 23mm shaft?...
                                            08-28-2026, 05:03 AM
                                          • dicky96
                                            Behringer Europower PMP3000 Mixer - LED Bar Meter sticks at high level
                                            by dicky96
                                            Hi guys
                                            I have this faulty mixer here. Basically the owner says it worked fine at one gig, then the next one it didn't
                                            When I power on, both the L & R LED Meters go to +4 and stay there. This is without any input and with all sliders Level Set knobs set to zero
                                            Also the LED meter on the 24-bit dual engine DSP goes to red (clip)
                                            I didn't connect an speakers but if I use headphones I can hear what I can best describe as a purring noise on both channels
                                            I found a schematic for the PSU There is a 10 way ribbon cable going from the PA/PSU...
                                            10-29-2021, 03:56 AM
                                          • Bektronics
                                            Schematic Digital Audio mixer RCF type M18
                                            by Bektronics
                                            Hello dear audio friends.
                                            I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                            The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                            I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                            Thanks in advance if anyone can help me with this schematic.
                                            Of course, all information about this digital mixer and possibly references...
                                            07-24-2023, 06:40 AM
