Behringer xenyx x1204usb mixer
This topic has been answered.
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 340
    • D12
    #41
    I assume this first one B50K would be ok to put in place of those two, right ?
    • check12
      • Nov 2012
      • 142
      Yes same as the already listed 6pin B50K with midpoint & 23mm shaft length for EQ etc ...
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 340
        • D12
        #43
        AC10K came but they don't have midpoint lol
        I wrote to seller
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 340
          • D12
          #44
          Can I use that AC10K instead of B503 6pin ? They are both without center pin.
          B50K link is now giving me 404 error
          • check12
            • Nov 2012
            • 142
            No.... AC pot has a completely different taper to a B pot.
            They are obviously completely different values too. AC10K = AC103. ....
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 340
              • D12
              #46
              ah, I will need new AC10K then with midpoint because this was for some reason without midpoint(center). I'll try and search it myself if you don't have time.
              • Thermaltake
                Brain badcap
                • Aug 2015
                • 340
                • D12
                #47
                I searched now on aliexpress but I can't find anything with midpoint AC10K 6pin 23mm shaft.
                does it matter if there is no midpoint, will it work normally without it if I put them instead of this original ones ?
                • check12
                  • Nov 2012
                  • 142
                  Lol... The pot with or without the midpoint is exactly the same electronically. The little click is only guidance for extremely low light conditions or blind users... electronically there is no difference....
                  Just use the correct values in the correct places...
                  • Longon
                    Behringer Pro Mixer DJX-750
                    by Longon
                    Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                    08-11-2025, 02:17 PM
                  • Thermaltake
                    Power button on Behringer Xenyx 1204USB mixer dead ?
                    by Thermaltake
                    Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
                    I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
                    08-16-2022, 03:22 AM
                  • mon2
                    EFX12 Mixer repair
                    by mon2
                    Hello. Curious if anyone here has worked on the Soundcraft EFX12 mixer repair? Not convinced if are dealing with an original Soundcraft unit or a high copy of the original. The offshore market appears to have cloned this unit - tons on Aliexpress / Alibaba.
                    The public schematics of the EFX12 from Soundcraft do not match the board we are servicing. After some review, have serviced most of the defects and noting a defective gain control potentiometer. Would anyone know of the value? From some internet searches, appears to be a C10k = 103 = 10k ohm reverse log pot with a 23mm shaft?...
                    08-28-2026, 05:03 AM
                  • dicky96
                    Behringer Europower PMP3000 Mixer - LED Bar Meter sticks at high level
                    by dicky96
                    Hi guys
                    I have this faulty mixer here. Basically the owner says it worked fine at one gig, then the next one it didn't
                    When I power on, both the L & R LED Meters go to +4 and stay there. This is without any input and with all sliders Level Set knobs set to zero
                    Also the LED meter on the 24-bit dual engine DSP goes to red (clip)
                    I didn't connect an speakers but if I use headphones I can hear what I can best describe as a purring noise on both channels
                    I found a schematic for the PSU There is a 10 way ribbon cable going from the PA/PSU...
                    10-29-2021, 03:56 AM
                  • Bektronics
                    Schematic Digital Audio mixer RCF type M18
                    by Bektronics
                    Hello dear audio friends.
                    I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                    The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                    I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                    Thanks in advance if anyone can help me with this schematic.
                    Of course, all information about this digital mixer and possibly references...
                    07-24-2023, 06:40 AM
