100ohm flameproof resistors
  • shaunbt123
    • Nov 2012
    • 119
    • uk
    Hi there
    can some one tell me the best place to get some 100ohm 1/4 watt flameproof resistors in uk.i can find plenty of 100ohm 1/4 watt resistors but they dont state they are flameproof.
    (ref) (part no) (remark)
    (R621) (1-249-899-110) CARBON 100 (5% 1/4W F) is what is listed in the parts list.
    its for a sony amplifier model ta-fb920r.
    thank you.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: 100ohm flameproof resistors
    Nearest I can find is this
    http://cpc.farnell.com/1/1/75745-res...ji-welwyn.html
    It is flameproof and 100ohms but is 1watt - I dont believe that matters as long as it is greater than you need providing it will physically fit.
    • shaunbt123
      • Nov 2012
      • 119
      • uk
      thanks selldoor
      what about it been 1 watt instead of the 1/4 watt, would it be a problem.
      oops sorry missed your comment at the end of your post.
      • redwire
        • Dec 2010
        • 3912
        Another name is "fusible resistor", you might want to look for instead. Yageo FRM series pdf
        I would say the service manual is wrong, as carbon composition resistors are pretty flammable.
        • Elysarian
          • Mar 2013
          • 200
          http://uk.rs-online.com/web/p/throug...stors/2671733/
          This what you're looking for?
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
            Acer Aspire A315-42G-R621 Notebook 3 Specification for Upgrade or Repair
            This specification for the Acer Aspire A315-42G-R621 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-42G-R621 boardview and A315-42G-R621 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 04:10 PM
          • chth96
            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
            by chth96
            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
            Since then, This AC/DC adaptor have been out of order.
            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
            And Is there any possibility that it will suddenly explode as well as to be out...
            12-03-2023, 04:40 AM
          • brightest_z
            Hot Air Blew Away Resistors Near Bios
            by brightest_z
            Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
            Does anyone with more knowledge, and experience than I, know if this is the case?
            12-11-2024, 08:34 PM
          • jinu_j
            LED driver circuit. Burnt Resistors
            by jinu_j
            Hi Folks
            This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
            Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
            But i have some queries on this circuit
            1. The resistors that burnt to crisp...
            08-26-2020, 01:24 AM
