AEK fuse specifications
  • Evets
    • May 2024
    • 28
    I'm repairing a pioneer amplifier and all the fuses have been removed, the service manual has part numbers but no fuse specifications. The fuses are all AEK with three numbers, is there a specification sheet for these AEK fuses?
    • 31258
    list the amplifier and whats on the fuses
    i presume nothing is printed on the boards
    • Evets
      • May 2024
      • 28
      The amp is a pioneer sa530, there are 4 internal fuses all of which are missing, the board is marked fu1, fu2, fu3, and fu4.
      I'm guessing one is mains voltage and the others are for the voltage rails or speaker protection. Initially I propose to use 2 amp fuses with a current limited supply while I check out the rest of the amp. Hopefully by then I can replace them with the correct values. I still have lots to learn with this new hobby.
      • petehall347
        • Jan 2015
        • 4445
        ok here you go .. just work out which model yours is . Click image for larger version  Name:	Screenshot from 2024-07-09 19-46-43.png Views:	0 Size:	63.4 KB ID:	3305937
        • Evets
          • May 2024
          • 28
          Thanks.
          • petehall347
            • Jan 2015
            • 4445
            the T is time delay .the others quick blow .
            • petehall347
              • Jan 2015
              • 4445
              be careful here if this is your model ..
Name:	Screenshot from 2024-07-09 19-52-29.png
              • petehall347
                • Jan 2015
                • 4445
                this should help ..
Name:	Screenshot from 2024-07-09 19-54-53.png
                  • 31258
                  other than all fuses being T variant anti-surge that is the most unclear shit i'v ever seen - and i'v seen a lot of japanese manuals!
                  • petehall347
                    • Jan 2015
                    • 4445
                    i thought it was straight forward after finding the right page . there appears different views on the speaker fuses depending on the model . there is choice of regular fuses and time delay .
                    • R_J
                      • Jun 2012
                      • 9607
                      AEK-xxx is just pioneer's part number like there c42, c43 caps are ACH-239 (5600µf42v)
                      FU2, FU3 are in the L, R output so output transistors may be bad.
                      • petehall347
                        • Jan 2015
                        • 4445
                        voltage selector fuses can cause sparks and more if both fuse holders are occupied .this is why i said be careful with that model
                          • 31258
                          make sure you buy ceramic fuses, not glass ones.
                            Surface Mount Fuses Fundamentals Datasheet
                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                            10-07-2024, 06:07 AM
                            TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                            FF Series (Very Fast Acting), 0603 Size
                            Features
                            ● Very fast acting at 200% overload current levels
                            ● Low DCR
                            ● High inrush current withstanding capability
                            ● Fiberglass enforced epoxy fuse body
                            ● Copper termination with nickel and tin plating
                            ● Halogen free, RoHS compliance and lead-free
                            Applications
                            ● Notebook computers and tablets
                            ● Digital cameras
                            ● Memory cards
                            ● Toys
                            ● Bluetooth earphones
                            ● Portable electronic devices​...
                            10-07-2024, 05:50 AM
                          • eidam655
                            GPU 1206 SMD fuse markings & replacement fuses
                            by eidam655
                            I need to replace a fuse on one of the graphics cards I am working on. It is a 1206 SMD fuse, white in color and has a "10" written in a blue rectangle on it.
                            How do I find a suitable replacement? What is the general rule to identifying fuses' parameters? I found something in an eshop near me (see photo) but am very hesitant to use this as a replacement....
                            04-14-2022, 12:46 AM
                          • jesterace
                            Samsung UE46ES8000 Blown fuse but no other signs of short
                            by jesterace
                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                            09-11-2024, 03:14 PM
                          • jshhh
                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                            by jshhh
                            Hi guys,
                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                            Anybody know how to remove this type of fuse?
                            (The fuse is toward the bottom of the image labeled F2)...
                            06-17-2025, 01:35 AM
