Logitech R20 speakers - Replacing one of the speakers.
  • Widget
    • Aug 2015
    • 74
    Hi guys,
    I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
    Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
    Printed on the back of the Logitech speaker is;
    LOGITECH
    EB-H02000040700-B
    4ohms
    2W
    831
    I ideally would like to fix the speakers. I don't like waste, especially if it can be fixed, I'd rather have them as a backup or connect to laptop, but at the same time whether they can be fixed cheap enough. I've never purchased replacement speakers before so I'm not sure what to look for. Any assistance would be super.
  • tmcw
    Stereo speakers to mono speaker
    by tmcw
    I picked up this set of powered PC speakers, no name brand, power cord to one of the speakers, and two audio cables coming out of it, one going to the other speaker, and the other to a 3.5mm jack for plugging into an audio out source.
    So, a typical cheap powered PC speakers setup.
    Now, the sound is pretty decent, I must admit, from the 4 ohm, 3W speaker, but I say "speaker", because it's just coming out of one of the speakers, and not the one with the power cord coming out of it. The other speaker is ok, it's just the electronics going to it has probably a fried...
    05-12-2021, 08:04 AM
  • RetroComputingGrotto
    Behringer MS16 Speakers - Low Volume on One Speaker
    by RetroComputingGrotto
    I've had a set of speakers come in with the fault of not powering on.
    I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
    1 random loose nut and part of a BIC Biro pen.
    After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
    05-20-2024, 07:29 AM
  • basskilla
    Logitech X-140 speakers buzzing is it normal?
    by basskilla
    Hi There!
    I bought secondhand Logitech X-140 speakers,it is old but it think the quality is all right.
    My problem it has background buzzing noise even if nothing is connected to it.
    It is not too loud,but if the room is quiet,it is noticeable.
    if I touch the metal cover,or the tone knob the noise is louder,I have the plastic cover knob,but I don't know is this noise normal or not.Sounds like a grounding issue or something like that.
    I tried to resolder the jack connection but nothing changed.
    Here is a little video about the speakers:...
    01-21-2023, 07:20 PM
  • Califauna
    Help with boom box modification
    by Califauna
    Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
    I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
    From factory the specs of the boom box are:
    -Power Input: DC 5V
    -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
    -Drivers:
    -2 x Woofer, 70mm, 10Ω, 70mm,15W
    -2 X Tweeter, 8Ω, 30mm,10W x 2
    -Frequency...
    12-04-2021, 01:53 PM
  • Delicieuxz
    Replacing caps in an old speaker system. Should I use a higher value here?
    by Delicieuxz
    I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
    https://youtu.be/1LRIzePlma0?t=273
    I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
    Would 680uF be good value to try in place of the 470uF originals?
    06-25-2023, 08:27 PM
