Logitech X-140 speakers buzzing is it normal?
  • basskilla
    • Mar 2014
    • 18
    • Hungary
    Hi There!
    I bought secondhand Logitech X-140 speakers,it is old but it think the quality is all right.
    My problem it has background buzzing noise even if nothing is connected to it.
    It is not too loud,but if the room is quiet,it is noticeable.
    if I touch the metal cover,or the tone knob the noise is louder,I have the plastic cover knob,but I don't know is this noise normal or not.Sounds like a grounding issue or something like that.
    I tried to resolder the jack connection but nothing changed.
    Here is a little video about the speakers:
    https://www.youtube.com/watch?v=8hEqiBs-f7w
    Is it a normal behavior of the speakers?If it is not,how can I fix it?
    Thank You for Your reply!
  • petehall347
    • Jan 2015
    • 4477
    Re: Logitech X-140 speakers buzzing is it normal?
    not normal
    • basskilla
      • Mar 2014
      • 18
      • Hungary
      not normal
      Thanks,any suggettison or tip to fix it?
        master hoarder
        • May 2008
        • 12182
        • Fixing stuff
        Open them up and post some pictures.
        Could (very likely) be the power supply filter cap(s) gone bad.
        I don't see a power adapter with these, so that means the power supply is in the speaker boxes. Not sure if it's oldschool AC line traffo or new SMPS design... but either way, this smells like bad caps problem to me.
        Also, do make sure to use them with the plastic knobs on there. The reason the sound goes louder is because you're coupling stray AC mains picked up by your body to the electronics inside. Hence the AC hum you hear.
        • basskilla
          • Mar 2014
          • 18
          • Hungary
          Thanks for Your reply!
          Here are some pictures about the power supply and the amp board.
          The plastic knobs are on but the noise still noticeable.I tried to bypass the factory adapter and swap with an external one but the buzzing-hum still persists.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • electronics and DJing/producing music
            YES. A bit of hum and buzz is normal.
            All PC speaker systems have basically been designed and built with ground loops/ground faults from day one, and age on the capacitors and passives only makes it worse.
            A working TV? How boring!
            • keklikelektronik
              • Apr 2022
              • 7
              • bulgaria
              hi.sound have some parazites.you can change the capacitors.
              • petehall347
                • Jan 2015
                • 4477
                there are some dodgy looking solder joints that need attention . especially 1 next to R3
                • basskilla
                  • Mar 2014
                  • 18
                  • Hungary
                  Ok I will change the electrolytic capacitors.Do You suggest to change the ceramic ones also?
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8626
                    No. Only the electrolytic ones.
                    • R_J
                      • Jun 2012
                      • 9678
                      • Making Money
                      Changing caps is not going to fix this issue, The case and controls should be at ground potential and they are not, likely a broken ground wire (shield in cable) between the speakers and the source, Check that Black wire with the red, white and shield
                      • tony359
                        Onkyo SR806 buzzing noise on outputs
                        by tony359
                        HI all,
                        I'm trying to repair an Onkyo SR806. Originally it had the usual "faulty DSP" sympthoms but it turned out that the supply voltage of the DSP chips was oscillating. I found both capacitors after the linear regulators for the DSP supply to be dead and that was causing the issue.
                        Once that was resolved, I focussed on the other issue: a pretty loud buzzing noise from the speakers, the usual 100Hz (I am in the UK so we have 50Hz here).
                        I've unplugged the amplifier board from the inputs and there is NO noise so the issue is in the signal being...
                        12-17-2025, 03:39 PM
                      • stvhop
                        HP1955L Buzzing noise & interference
                        by stvhop
                        Hello, This is my first post so please forgive me if I miss out some vital info.
                        I have a problem with my HP1955L monitor from 2005.
                        The first thing to say is that it is still basically working, ie the picture is fine.
                        However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                        The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                        11-07-2020, 07:13 AM
                      • Orion Bardier Skylar
                        Adding Bluetooth module to Woofer buzzing noise
                        by Orion Bardier Skylar
                        Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
                        03-06-2024, 02:35 PM
                      • Boardview and Schematic Bot
                        LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                        This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                        09-12-2024, 01:58 PM
                      • tony359
                        by tony359
                        11-28-2023, 05:18 AM
