Behringer MS16 Speakers - Low Volume on One Speaker
  • RetroComputingGrotto
    • Aug 2023
    • 88
    • United Kingdom
    I've had a set of speakers come in with the fault of not powering on.
    I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
    1 random loose nut and part of a BIC Biro pen.
    After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
    Any advice on where I should start looking as I cant see any obvious signs of any issues. We've got quite a lot of these speakers and the ones I've repaired in the past had bulging capacitors but there dont appear to be any on this one so pointers in where the issue might be are very welcomed!
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Measure the resistance of every SMD resistors and compare with the speaker that is working normally. I see only a few on the bottom layer, so it's not a difficult thing to do.
    Film and ceramic caps you can ignore as they rarely ever go bad.
      • Aug 2023
      • 88
      • United Kingdom
      The speaker that works normally has no PCBs in it what-so-ever so unfortunately I cannot compare the SMD resistors. The amp is only in one of the 2 speakers.
      Interesting you think it's more likely to be a resistor than any other component so hopefully I can work out what they're supposed to be as I've not been able to find a service manual or schematics for these speakers yet.
      • tmcw
        Stereo speakers to mono speaker
        by tmcw
        I picked up this set of powered PC speakers, no name brand, power cord to one of the speakers, and two audio cables coming out of it, one going to the other speaker, and the other to a 3.5mm jack for plugging into an audio out source.
        So, a typical cheap powered PC speakers setup.
        Now, the sound is pretty decent, I must admit, from the 4 ohm, 3W speaker, but I say "speaker", because it's just coming out of one of the speakers, and not the one with the power cord coming out of it. The other speaker is ok, it's just the electronics going to it has probably a fried...
        05-12-2021, 08:04 AM
      • Mcfeetroy
        homemade speakers AN5277 How to adjust the volume?
        by Mcfeetroy
        Hello everyone. I soldered the speakers according to the circuit diagram on the AN5277 sound amplifier microcircuit. Everything works fine (I only added a ferrite ring to remove the sound transmission interference)
        But I can't adjust the sound (there is no variable resistor or something similar for this in the circuit....Please tell me how I can adjust the sound? What needs to be added to the circuit?
        10-27-2024, 10:19 AM
      • Califauna
        Help with boom box modification
        by Califauna
        Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
        I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
        From factory the specs of the boom box are:
        -Power Input: DC 5V
        -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
        -Drivers:
        -2 x Woofer, 70mm, 10Ω, 70mm,15W
        -2 X Tweeter, 8Ω, 30mm,10W x 2
        -Frequency...
        12-04-2021, 01:53 PM
      • karthur
        Vizio D65x-G4 Volume changes on its own
        by karthur
        On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
        It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
        06-05-2025, 08:13 AM
      • waigy
        Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
        by waigy
        As the title.
        I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
        It looks basic enough inside with large components so I could do a full recap pretty easily.
        Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
        If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
        I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
        11-08-2024, 03:53 AM
