Alarm Siren issue
  • petehall347
    • Jan 2015
    • 4440
    https://www.microchip.com/en-us/product/pic12c508a
    • slybunda
      • Feb 2012
      • 139
      fantastic. any ideas on how the read the code from this chip? can it be done with an arduino uno?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        Originally posted by slybunda
        removed the sticker of the small chip and its got some markings on it:
        12C508A
        04/P01V
        0113
        maybe if i can find a datasheet for this it may give schematic info of whats supposed to be connected to it and how?​
        Its a PIC microcontroller.
        • lti
          • May 2011
          • 2557
          That's a microcontroller, so it all depends on the program.
          Damn, I missed page 2.
          • redwire
            • Dec 2010
            • 3912
            OP cross-posted galore, it's ridiculous:
            https://forum.allaboutcircuits.com/t...n-issue.198936
            https://forums.overclockers.co.uk/th...ai606.18984085
            https://bobistheoilguy.com/forums/th...n-issue.378880
            https://www.eevblog.com/forum/chat/c...rm-siren-issue
            Must be a relative of treez Sound the siren I need attention.
            Is OP fixing it, but says they've bought a new one.
            Why bother with the MCU - if it's damaged, you ain't reading any code out of it, and even then the code protection bit is likely set.
            Can you fix this siren? Consensus: NO the board is cooked too badly.
            Why post all over the Internet?
            • petehall347
              • Jan 2015
              • 4440
              #26
              scrapyards are full of these things .
              personally i wouldn't bother and drive without it . its only there to make noise that nobody bothers about apart from complain .
              i did once remove one from a car because it kept going off whilst driving . had to stuff a rag hard against it
              to make it quieter it then remove it from the car when it was sounding then threw it in a bucket of water to shut it up .
              • slybunda
                • Feb 2012
                • 139
                #27
                i dont have a replacement siren for this one. someone is sending me a different type of siren which i may be able to use for parts.
                iv worked out the part of this siren thats used for charging the battery, looked like they used zener diodes for a constant voltage charging system, the big diode on the board is to prevent the battery in the siren back feeding to the alarm control box. this should be fixable once i get to look at another siren that uses a similar type of setup to get an idea of whats going where.
                no harm in posting in different places since people on different forums dont always go on all the other forums too.
                also you missed one more place where its been posted, can you find it?
                • slybunda
                  • Feb 2012
                  • 139
                  #28
                  iv tried 2 of the largest scrapyards in my city and nothing available from them. 10 years ago this would have been very easy to nab but now not even ebay etc has any. dont think anyone needs and aftermarket alarm and immobiliser since all cars came standard with it after year 2000 or so..
                  • slybunda
                    • Feb 2012
                    • 139
                    #29
                    Managed to get a replacement siren from a newer model alarm. Its not perfect but works well enough
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                      🛠 Original Issue
                      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • ugamazing
                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                      by ugamazing
                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                      12-17-2024, 07:05 PM
                    • shahnld
                      Lenovo legion 5 pro startup issue
                      by shahnld
                      Good day Experts
                      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                      08-24-2025, 12:31 PM
                    • ahmarzo
                      Acer laptop battery draining issue
                      by ahmarzo
                      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                      08-02-2025, 06:39 AM
                    • elmark
                      HP 15-cw1002ua strange keyboard issue
                      by elmark
                      HP Pavilion 15-CW1002UA
                      S/N 5CD0251CBC
                      P/N 7KE54EA
                      Hello guys!
                      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                      It powers on OK and has no other issues except the following:
                      • CAPS LOCK does not work at all
                      • Fn button toggles Flight Mode
                      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                      • (with SHIFT pressed: 't%' and 'y^' respectively)
                      I initially thought it was a keyboard malfunction (internal short, etc.),
                      but when I press and hold...
                      06-27-2025, 01:10 AM
