JVC RC-M90W Boombox component ID
  • m4a2t0t
    • Mar 2013
    • 276
    What kind of diode is D72 next to the fusible resistor? It looks like D723 but it blew up and all I can read from it is a 1 on one side and what appears to be an E or F on the other..
    Someone replaced a 5ohm fusible resistor with a 1w 5ohm resistor to get it working. It worked for an hour before it started smelling like burning plastic.
    Is the disc cap in the last pic just a ceramic cap?
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Could be the same as the other diode behind that TO-220 part, in between the resistor and the cap.. who knows.
    Unless that particular circuit asks for a specific forward/reverse bias voltage, maybe try putting in 1N4148?
    • m4a2t0t
      • Mar 2013
      • 276
      I didnt think I d find the schematic for it. According to the parts list its a HZ12B1 or a 12.9V max zener diode.
      Can I replace the ceramic disc caps with multilayer ceramic caps?
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        Yes you can. I use MLCC ceramic caps in all of my past audio projects with no degradation to the signal whatsoever.
        • m4a2t0t
          • Mar 2013
          • 276
          Everything is back together but the cassette wont play. Pin 5 of IC701 is 5.3V and drops to 0 when pressing the play button. Pin 14 stays at 0.03V when pressing play. None of the buttons work. Is IC701 bad? pin 18 is 5.3V
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
          • artvandalai
            What resistor ohm will work better to repair this waterpik?
            by artvandalai
            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
            01-05-2025, 04:10 PM
          • chth96
            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
            by chth96
            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
            Since then, This AC/DC adaptor have been out of order.
            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
            And Is there any possibility that it will suddenly explode as well as to be out...
            12-03-2023, 04:40 AM
