JVC RC-M90W Boombox component ID
  • m4a2t0t
    • Mar 2013
    • 279
    What kind of diode is D72 next to the fusible resistor? It looks like D723 but it blew up and all I can read from it is a 1 on one side and what appears to be an E or F on the other..
    Someone replaced a 5ohm fusible resistor with a 1w 5ohm resistor to get it working. It worked for an hour before it started smelling like burning plastic.
    Is the disc cap in the last pic just a ceramic cap?
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Could be the same as the other diode behind that TO-220 part, in between the resistor and the cap.. who knows.
    Unless that particular circuit asks for a specific forward/reverse bias voltage, maybe try putting in 1N4148?
    • m4a2t0t
      • Mar 2013
      • 279
      I didnt think I d find the schematic for it. According to the parts list its a HZ12B1 or a 12.9V max zener diode.
      Can I replace the ceramic disc caps with multilayer ceramic caps?
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        Yes you can. I use MLCC ceramic caps in all of my past audio projects with no degradation to the signal whatsoever.
        • m4a2t0t
          • Mar 2013
          • 279
          Everything is back together but the cassette wont play. Pin 5 of IC701 is 5.3V and drops to 0 when pressing the play button. Pin 14 stays at 0.03V when pressing play. None of the buttons work. Is IC701 bad? pin 18 is 5.3V
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • gica69
            Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
            by gica69
            I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
            Resistor shows orange range silver gold and green lines.
            Thanks in adv...
            07-21-2025, 09:49 PM
          • bluto
            Is this a fusible resistor?
            by bluto
            This is from the power supply of an LED shop light. The light went completely dead suddenly. I removed the SMPS board and it looked really good except for some bad solder joints. I touched all of them up but the light was still dead. I then found this open resistor that was between the neutral wire of the plug and the transformer. The color bands seem non-standard. Does it indicate 13 ohm, 30 ohm...? I am not sure. What should I replace this with?
            07-01-2025, 01:30 PM
          • youpla
            PowerColor rx 5700xt dual fan : current sense resistor
            by youpla
            I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
            The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
            The card wasn’t displaying anything after this fix.
            When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
            I tried to resolder it with a hot air station, but the resistor wouldn’t...
            Today, 07:52 AM
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
