Sony HCD-GRX800 Switches off within seconds after it is switched on
  • reality
    • Mar 2013
    • 50
    • Nigeria
    Please help, Sony HCD-GRX800, when plugged to mains, switches on and switches off again. I have tested the power section and the STK amplifiers if there is any short circuit that is preventing it to sustain power but there all seems okay. Can any one please tell me what else to do?
    I will appreciate suggestion from any experienced member.
    Thanks in advance!
  • mauda
    Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
    by mauda
    I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
    Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
    05-21-2023, 11:56 PM
  • tec3000
    Sony LED 65X9005A shuts down after few seconds - looking for help
    by tec3000
    Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
    I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
    03-20-2024, 07:29 AM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • ravi_1617
    Sony MBX-223 ,M971 , Shutdown after 40 seconds
    by ravi_1617
    Hi.! This Sony board turns off after 40-42 seconds.
    (with adaptor/battery or both)
    Don't turn on until 20 seconds,
    If I disconnect Power immediately when off,than I can turn on, than again stays on same time, aprox 40 seconds
    Did changed ,
    thermal paste, CPU.
    Flashed bios also.
    fan heatsink also clean
    Before turning off fan also turns on.
    Any points I am missing
    08-31-2021, 11:42 PM
  • Yosua
    sony vaio MBX-237 every 35 seconds it turns off again
    by Yosua
    hi friends, I want to share about my problem with the mobo SONY VAIO MBX-237, the case is when pressing the power button it turns on (without display) but in 35 seconds it turns off again, I have measured the resistance on all coils, and the result is 1 coil near the vga chip there is no voltage when the mobo is on, and my problem is because on this mobo there is no code for each component, I hope someone can help me here, thank you....
    03-27-2022, 08:14 PM
