Yamaha HT-R4065 won't start
  • tibimakai
    • Jan 2012
    • 3680
    Re: Yamaha HT-R4065 won't start
    I will check it out in the morning.
    • tibimakai
      • Jan 2012
      • 3680
      It was open.
      So this caused the blow up, right?
      I should receive the ordered components on Friday.
      • rievax_60
        • May 2012
        • 897
        • australia
        Originally posted by tibimakai
        It was open.
        Yes, that is a good reason for the output transistors and drivers failing.
        Is the bias transistor ok?
        • tibimakai
          • Jan 2012
          • 3680
          Yes it's fine. I have ordered another one just in case.
          I would like to ask you about this transistor, why they are installed under the main heatsink with thermal paste?
          • rievax_60
            • May 2012
            • 897
            • australia
            Its for thermal feedback.
            As bipolar transistors increase in temperature, they will conduct more Collector to Emitter current for a given applied Base to Emitter bias voltage, Vbe.
            This would cause the idle current though the output transistors to increase causing more temperature rise and higher idle current again. This process will snowball until the transistors fail.
            The bias transistor or Vbe multiplier as its also called, controls the total bias voltage that is shared out to the Base to Emitter junctions of all four transistors in the output stage. Notice that all of the Base/Emitter junctions are kind of all in series with each other.
            As the bias transistor senses higher heatsink temperature, the resistor divider strung from its Collector to Base to Emitter causes its Collector to Emitter voltage to decrease because now the the bias transistor itself needs less applied Vbe to be turned on.
            Also notice that the Collector and Emitter of the bias transistor connect to the Bases of the output's driver transistors.
            The actual bias current is supplied by the preceding signal voltage amplifier stage.
            • rievax_60
              • May 2012
              • 897
              • australia
              #26
              It prevents thermal runaway.
              • rievax_60
                • May 2012
                • 897
                • australia
                #27
                The Collector to emitter voltage of the bias transistor at where its turned on enough to bypass the 5ma or so from the voltage amp stage becomes its Vbe multiplied by the resistor divider's ratio.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Thank you so much for the explanations, but it's a bit to much for me.
                  I will never understand these circuits as well as you. I don't even plan on learning that well.
                  I have never learned about electronic components, or how they work.
                  I'm a machinist by profession. I'm more a "mechanical" type guy, who pokes around with electronic devices to keep me busy and make some extra money.
                  I appreciate a lot, all the help that I'm getting from you. You are a really knowledgeable person.
                  You asked me in the other thread, if the transistor turns on, I don't even know how would I know if it's turning on or not. I'm just being honest here. I know that a diode opens up around 0.6V. I should have at least 0.6V between the Base and Emitter of the transistor?
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #29
                    The 0.73v on the Base, assuming that the Emitter is firmly tied to ground at 0v,
                    implies that a reasonable amount of bias current is flowing into the Base.
                    Also the voltage drop across R319 calculates to 1ma of current.
                    The transistor's specs say it has a minimum gain of 150. It should be capable of conducting at least 150ma from its Collector pin to its Emitter pin.
                    If there was no problem and the receiver turned on, I would expect to see about 7.5v at the top of the relay coil and close to 0v at the transistor's Collector pin which is also connected to the bottom end of the coil.
                    I hope Q302 isnt really fitted?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      What do you mean by fitted.
                      Maybe we should switch back to the the other thread.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #31
                        It has dotted lines around it which means that its optional. Its purpose is to shut the receiver down if the mains voltage gets too high.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Some of the transistors are on backorder, I need to wait a little bit more with this receiver.
                          I guess, I will spend some time with TVs this weekend, and I may replace some speakers in my new Mazda CX5.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I'm trying to get back to this receiver and I'm noticing that I have got a NTE36 and a 2SA1941 transistors. It's a good idea to install this pair, or should I get the matching transistor?
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Anybody?
                              These are the final pair of transistors, at the broken surround channel.
                              The original pair it was 2SA1941/2SC5198. I can't seem to find the 2SC5198.
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #35
                                The NTE36 should replace the 2SC5198 ok.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  After I replace the blown parts, can I just leave out the finals and start it up this way?
                                  If it doesn't blow, then it's safe to install them? This channel, without finals it should make any sound? Can I hook up a speaker to this channel?
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #37
                                    You can leave out the output transistors for safe testing. The feedback loop needs to be still closed in the design for the output to balance at zero volts.
                                    In many designs, there are resistors between the driver transistor's emitters and the amplifier output, which completes the feedback path while the output transistors are missing.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Here is the schematic:
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Do you think that I could hook up a speaker too? Last time it blew when I hooked up the speaker.
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #40
                                          You can connect a speaker, you need to keep an eye on the signal level at the driver transistor's emitters. It is best not to.
                                          Confirm the output is near zero volts, then measure the voltage difference between where the base of the output transistors would be connected. It should be close to one volt.
                                          • nzphil
                                            Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
                                            by nzphil
                                            I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
                                            04-11-2021, 05:58 PM
                                          • sanalelevenstar
                                            Yamaha RX-V485 Wn9711 Update
                                            by sanalelevenstar
                                            Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                            I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                            I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                            12-04-2024, 04:32 AM
                                          • sanalelevenstar
                                            Yamaha RX-V485 receiver. After encountering a "version error"
                                            by sanalelevenstar
                                            I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                            After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                            I managed to find the service...
                                            09-10-2025, 01:54 AM
                                          • jjne
                                            Yamaha RX V675 sound issues
                                            by jjne
                                            I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                                            From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                                            At first I thought it was either a speaker relay or the DSP, but I don't think...
                                            06-24-2025, 07:01 AM
                                          • AlexVG
                                            YAMAHA CLP-550 without of sound
                                            by AlexVG
                                            Hi.
                                            I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                                            I have replaced all green marked elements, but it gave me nothing.
                                            The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                                            But it is custom YAMAHA's chip, and I can't find any information about it.
                                            Maybe somebody came across with the same issue?
                                            Any information will be very useful. I will be very appreciated.
                                            Thank you....
                                            06-08-2025, 09:29 AM
