Yamaha HT-R4065 won't start
  • tibimakai
    • Jan 2012
    • 3680
    Re: Yamaha HT-R4065 won't start
    I went for it, installed everything, measured all the amp components (compared to other channel) and turned it on. Nothing blew up this time.
    It works very well.
    It's alive!!!
    Thank you very much for your help, I appreciate it a lot.
    • nzphil
      Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
      by nzphil
      I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
      04-11-2021, 05:58 PM
    • sanalelevenstar
      Yamaha RX-V485 Wn9711 Update
      by sanalelevenstar
      Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
      I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
      I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
      12-04-2024, 04:32 AM
    • sanalelevenstar
      Yamaha RX-V485 receiver. After encountering a "version error"
      by sanalelevenstar
      I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
      After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
      I managed to find the service...
      09-10-2025, 01:54 AM
    • jjne
      Yamaha RX V675 sound issues
      by jjne
      I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
      From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
      At first I thought it was either a speaker relay or the DSP, but I don't think...
      06-24-2025, 07:01 AM
    • AlexVG
      YAMAHA CLP-550 without of sound
      by AlexVG
      Hi.
      I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
      I have replaced all green marked elements, but it gave me nothing.
      The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
      But it is custom YAMAHA's chip, and I can't find any information about it.
      Maybe somebody came across with the same issue?
      Any information will be very useful. I will be very appreciated.
      Thank you....
      06-08-2025, 09:29 AM
