Yamaha HT-R4065 won't start
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this receiver in very good condition with all the accessories.
    All it does when it is turned on, is the power button LED it blinks a couple of times.
    I have downloaded from elektrotanya the SM for the HT-R4063, which seems pretty close to this one.
    I have managed to turn it on in service mode, without protection turned on.
    Not sure what to do next. Anybody has any input? Not sure what is causing to get into protection mode.
  • newbiesat
    • Dec 2012
    • 25
    • usa
    Re: Yamaha HT-R4065 won't start
    Do you check the output transistors to see any short out ?
    • tibimakai
      • Jan 2012
      • 3680
      After I have posted that I have took it apart and I didn't have time to check all of them but I have found a pair shorted after the first measurements. After cutting there legs it was still in protection mode, most likely some other components are shot too.
      I'm having difficulty removing the wire ribbons from there connectors. The ones from the HDMI board.
      It seems like the plastic tab slides out, but the ribbon doesn't want to come out.
      Any pointers?
      On the Onkyo receivers, the tab has to be pushed in to release the ribbon.
      • tibimakai
        • Jan 2012
        • 3680
        I have found a couple bad parts, I will post the list when I will be home.
        I'm having difficulty with a SMD diode. The marking is A2, found at another channel, because the surface is to rough to be able to read the marking off of that one.
        When I'm looking for this diode, under that marking are a couple of other diodes show up, which one should I look for? A basic 1N4148 in that package should be fine?
        http://www.marsport.org.uk/smd/mainframe.htm
        • tibimakai
          • Jan 2012
          • 3680
          Nobody can help with the A2 diode?
          • tibimakai
            • Jan 2012
            • 3680
            It was a 5.1V zener diode.
            Replaced all the bad components, that I have found, and after clearing th error, the receiver turned on and worked fine with the front speakers, when I connected the two rear channels(SL had the issue), then the same channel. Luckily, I have another set of parts.
            What should I check next time, before I turn it on?
            It blew up only with load, without speaker it was fine.
            • tibimakai
              • Jan 2012
              • 3680
              Found the amplifier schematic in another Yamaha receiver. The one that I have found earlier, did not match my receiver.
              I have replaced the two finals, the two pre finals, the zener diode, the .22 ohm resistor(one side it was open), a 120 ohm resistor(need to check which one).
              What do you guys think, which component did I have missed.
              Now I will have to check which ones blew up.
              • tibimakai
                • Jan 2012
                • 3680
                If the DC bias is the same as the rest of the channels, then that channel it should be fine? I can connect the speaker?
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have managed to blow it again. It had even caught fire.
                  I would really need some help here.
                  I have tested each component at this amp. All were OK.
                  At first didn't want to turn on, then I have reset it with Tone control+Info+Powr on and then blew up.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    At what point did it fail?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      First time I have managed to clear the error and the unit turned on. Only when I connected that speaker(SL channel) blew up.
                      Now, when I cleared the error, blew up right away.
                      I have measured the finals against the heatsink, they were all fine, no short there.
                      R2123 cut fire. It's the resistor at the emitter of the PNP pre amp transistor.
                      The schematic that I have it's not exactly the same as mine.
                      The first part of the amp: Q2005, Q2012 and Q2019 section, it's not there.
                      The whole amp section, is so simple and I have managed to blow it up two times. I can't believe it that it happened.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        If the 5.1v zenner was shorted before, it implies that Q2028 is intermittently disconnecting or has been blown open circuit.
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          The circuit you posted shows that the feedback loop remains closed even when the output transistors are removed. You can take advantage of this to do some relatively safe testing.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            The zener blew each time. Q2025, it's the SL channel. That transistor is under the heatsink.
                            To me it seemed OK when I have removed it and tested it.
                            I will order a new one, it's not cheap and hard to find.
                            I have ran out of parts, I need to order new ones.
                            0.22 Ohm resistor is open, the finals, pre finals are all bad, the 120 Ohm resistor is burned.
                            You are saying that I should start it up next time without the finals?
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              Yes, that is an option. You need to check that the feedback loop really closed like in the yamaha amp.pdf
                              Do you understand the function of that small transistor under the heatsink and what happens if it goes open circuit because of a cracked solder joint?
                              • tibimakai
                                • Jan 2012
                                • 3680
                                No, I don't understand and that may be the case. At one of the pins the copper ring has lifted.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  Its not a good idea trying to fix amplifiers without leaning something about how they work. I think we have been over this ground before.
                                  If any pin on that transistor has really become disconnected from the circuit, all output transistors turn on hard drawing over current from the rails.
                                  I can see why 2SD2705S is expensive. Its primary function is as "mute transistor" which are becoming scarce for some reason.
                                  If it has failed this time, try to find something else that is used in the same location in another brand/model.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I know that I should learn about amplifiers, but I don't want to be an expert in these.
                                    I'm repairing LCD TVs as a hobby to make some side money. Receivers are just to fill in, when I don't have TVs to repair.
                                    I had a bad feeling about that transistor, but it seemed like it was OK.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      That transistor is 2SD1915F, not as in that schematic.
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        The transistor may still be ok. I would rather blame the lifted pad you mentioned.
                                        Does it look like the track is really broken. If it wasnt actually broken, then this is not the reason for the output transistors failing.
                                        • nzphil
                                          Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
                                          by nzphil
                                          I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
                                          04-11-2021, 05:58 PM
                                        • sanalelevenstar
                                          Yamaha RX-V485 Wn9711 Update
                                          by sanalelevenstar
                                          Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                          I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                          I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                          12-04-2024, 04:32 AM
                                        • sanalelevenstar
                                          Yamaha RX-V485 receiver. After encountering a "version error"
                                          by sanalelevenstar
                                          I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                          After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                          I managed to find the service...
                                          09-10-2025, 01:54 AM
                                        • jjne
                                          Yamaha RX V675 sound issues
                                          by jjne
                                          I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                                          From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                                          At first I thought it was either a speaker relay or the DSP, but I don't think...
                                          06-24-2025, 07:01 AM
                                        • AlexVG
                                          YAMAHA CLP-550 without of sound
                                          by AlexVG
                                          Hi.
                                          I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                                          I have replaced all green marked elements, but it gave me nothing.
                                          The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                                          But it is custom YAMAHA's chip, and I can't find any information about it.
                                          Maybe somebody came across with the same issue?
                                          Any information will be very useful. I will be very appreciated.
                                          Thank you....
                                          06-08-2025, 09:29 AM
