Got an old Marantz SR5300 receiver. It will switch off almost immediately after I switch on with remote controller. The LED is solid red and not blinking. I remove all add on cards and left only the main board, still the amp switch off. by removing the 2 ribbon cables, the amp stay on with display and I'm able to switch inputs, of course, theres no input but I can hear a click between inputs.
I suspect its the transistor that cause the problem but I really don't know how to check. they are SPA16P and SPA16N, I'm noob in transistor, could anyone guide me how to check for fault?
This is the Amp board
http://postimg.org/image/pupfigfn9/full/
This is Schematic
http://postimg.org/image/nbxhkt4r7/full/
Click the link for 3.5k RES, if image won't load, please see the attachment, they are only 2k res.
This is Schematic
To re-join them, it should be enough to scrape off some of the solder-mask on both sides of the cut, and make a solder-bridge (if it's stubborn, stick a piece of not-that-thin wire into the solder).
I'm keeping my fingers crossed, hope it stay that way until I find a reason to upgrade.
Didn't expect the Pre/Power from HK can have such a shabby job in soldering.
then again, at least there's a way to fix if they gone bad, unlike the LSI circuit boards today.
